Which oil to use...
Old May 9, 2005 | 11:26 AM
henry_mark0's Avatar
Which oil to use...
I have put 2225 miles on my 05 G 6mt. I am planning to changing my oil..... any ideas on which oil to use.... any specific brand..... Could I have it changed at PepBoys, autozone.... or similar....
Thanks for you input guys...
Cheers
Henry
Old May 9, 2005 | 11:28 AM
GeeWillikers's Avatar
Walking The Fine Line...
Using the word 'oil' in the 'search titles' function of the 'advanced search' feature I found this:
https://g35driver.com/forums/showthr...&highlight=oil
It should help.
Old May 9, 2005 | 02:30 PM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
Try Motul 8100 It's a Synthetic Made By a French Oil Company Vey big in Racing..........
Old May 9, 2005 | 04:22 PM
Guys,
Are you asking me to go synthetic with 2k+ miles on my car...
Old May 9, 2005 | 04:23 PM
If I were you (and of course I'm not or I'd be talking to myself right now) I'd pick the brand that I'm most comfortable with that met the MFR specifications.
Old May 9, 2005 | 04:24 PM
I called up the dealership and found that they use mobil 5w30 non synthetic. I check with another dealership and they seem to be using mobil1, which I presume is synthetic.
Is oil dealer's preference and is it not a standard across all infiniti dealerships?
Old May 9, 2005 | 05:13 PM
SDG35619's Avatar
I thought Infiniti used oil made by Nissan?...is there such a thing?
Old May 9, 2005 | 05:31 PM
G6MT's Avatar
G'z 6MT
From: Mo-town(Modesto) Bay Area (Silicon Valley), CAL
Use MOBIL1 full synthetic (5W-30)
Old May 9, 2005 | 06:17 PM
RBull's Avatar
Rated M
Mobil one has a relationship with Infiniti and many dealers are offering their products, although not exclusively. AT 2k miles you're about at the range to switch to synthetic now that your engine major break in period is over. I recommend the mobil one 5w30 synthetic.
Old May 9, 2005 | 06:20 PM
RBull's Avatar
Rated M
I don't believe there are any auto manufacturers that have their own refineries. Although there are lots of manufacturers that carry their own brand of oils, lubricants manufactured for them by others.
Old May 9, 2005 | 06:23 PM
SDG35619's Avatar
ahh i see...
I asked because I've owned Ford trucks and Ford uses Motorcraft oil. I thought every manufacturer used their own oil.
Old May 10, 2005 | 07:18 AM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
That's funny...mentioning Motul 8100 in a thread that also contains Pep Boy and Auto Zone. You can change over to synthetic anytime you want. As mentioned a million times before, new Vipers and Corvettes come with Mobil1 already installed. have fun........
Old May 11, 2005 | 02:03 AM
trebien's Avatar
That "3-in-1" stuff works pretty well... comes in a little red and white can.
It takes a bunch of those 2 ounce cans to fill up the engine, though...
Old May 11, 2005 | 10:17 AM
NismoV35's Avatar
Try Lard, Remember what Emeril Says PORK FAT RULES!
Old May 11, 2005 | 09:27 PM
RxCritical's Avatar
I would recommend doing it yourself if you are at all mechancially inclined. I would venture to guess that most of the 19 year olds that are changing the oil at your local lube place do not give a flying rat's a$$ about whether the correct amount was put in or if the engine skirt is replaced properly. You, however should have a vested interest in such things. And it is somewhat enjoyable to know you did it.
