Messed up compass by trying to set zone number
Old May 17, 2005 | 08:18 AM
Corgidog's Avatar
I was reading the manual and it had a map showing your geographic zone and it said to hold the compass button for 5 secs and it will show your zone and to repeatedly hit the compass button to adjust your zone to the correct one. I live in NJ and my zone is 9 so I held the compass button down for 5 secs thinking I would see 9 or another number. Instead I got 3 short dashes which don't change even after I repeatedly hit the compass button as per the manual. So now instead of N, S, W, or E showing on the compass I am getting 3 dashes like "_ _ _" I tried turning the compass on and off but when in the on position all I keep getting are _ _ _. How can I get my compass back? Thanks
Old May 17, 2005 | 11:24 AM
doogie's Avatar
Drive around in a circle slowly like twice. It has to figure out where it is now.
...If you'd read further in the manual you'd have seen that bit too
Old May 17, 2005 | 01:51 PM
mhollinger's Avatar
That's my favorite little instruction in the manual: (Paraphrasing) Drive in circles until the car figures out where its going.
I do that until I figure out where I'm going.
What you ended up doing is resetting the digital compass. Now it has to recalibrate itself and figure out which way is "north."
Old May 17, 2005 | 02:06 PM
Lip's Avatar
Lip
Try holding down the compass button, then turn on the ignition.
This should bring it back to normal.
Turn the car off.
Then do the same thing, hold down the Compass button while turning on the ignition. release the button
This time you should be given Numbers, select by pressing the compass button until you find your zone.
Old May 17, 2005 | 04:24 PM
Andy77's Avatar
"all I keep getting are _ _ _. "
That means the hood is pointed to the sky
Actually, having it try to find itself sounds like a good idea. Anyone know how this actually works? I had the same instructions in my Dodge Caravan years ago and didn't know how driving in a circle helped it out.
Old May 17, 2005 | 04:37 PM
Msedanman's Avatar
O.F. Administrator
To orient itself, you need to drive around in a circle 3 times slowly at less than 5 mph, in one direction, (complete circles), then in theother direction (less than 5 mph).
Find a deserted parking lot somewhere to do this.
C.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
Team STILLEN
Aug 10, 2015 08:17 PM
itschuckster
Jul 25, 2015 08:07 AM
igking
Jul 19, 2015 01:12 AM
