Z mid-pipe on sedan?
Old May 23, 2005 | 04:55 AM
tju62's Avatar
Question Z mid-pipe on sedan?
Anyone out there know if the 350Z mid-pipe will fit on a 05 Sedan?
Thanks in advance.
Old May 23, 2005 | 06:16 AM
JustBrilliantX's Avatar
Misanthropic nut-cracker
From: On the water at the "Jersey Shore"...Toms River
Try the search engine............topic has been covered ta death. 350 is too short...use the G35 cpe. middy
Old May 23, 2005 | 09:41 AM
jaspergtr's Avatar
with an extension from performance nissan...
Old May 23, 2005 | 01:13 PM
why even bother with adding the Nimso extention when the G35 cpe. middy fits perfect to begin with...........unless the author of the thread has the opportunity of gett'n a freebie from a 350?
Old May 23, 2005 | 03:35 PM
jaspergtr's Avatar
yeah... i didn't read into his question too much. either he's gotten one for cheap, or he didn't do a search. either way, he's got his answer.
good luck with your mods!!!
Old May 23, 2005 | 05:35 PM
tju62's Avatar
Thumbs up mid-pipe
Thanks everyone.
Old May 24, 2005 | 12:41 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Thanks in advance.
If you intend to add a Y-pipe as well,
then the Z midi is not a bad choice.
Most if not all Y-pipes are larger DIA than the midi pipe.
You can make up a 6" taper transition to suit the size difference.
Otherwise stick with the coupe pipe like others have said.
Jusseth
Sep 13, 2020 12:25 PM
TheKnite
Aug 14, 2015 07:59 PM
chinee
Aug 8, 2015 10:11 AM
wuppiedog
Aug 7, 2015 11:16 AM
teamghost
Jul 28, 2015 04:52 PM
