Starting to Ping!?!
#46
Southern California Gas and maybe the San Francisco area use a mandated additive in the gas for about half the year to help reduce emissions. In the San Fernando valley most of the people I knew were of the opinion, shared pretty widely throughout the area, that the oxygenated gasoline did not perform as well as gasoline without the additives. I've run my Altima on 87 since I bought it as that is what the manual says is required. 91 is an option for 'maximum performance', not really important in an Altima. I will use 93 in northern California while traveling through the mountains because the engine will ping on 87 accelerating up some of the passes. Here in the Seattle area the difference between 87 and 93 is about 10 to 15 cents, for the next grade up the price jumps about 20 cents. Someone will correct those numbers as I don't pay that much attention to them. We only have two refineries up here, BP and ARCO so virtually all the gas sold in this area comes from one of those two refineries regardless of where you buy it.
#47
Originally Posted by OCG35
Okay, let’s set the record straight… On the ‘04 sedan (at least mine) the inside filler door says “Premium fuel recommended for maximum performance”.
The owner’s manual (attached) says: 87 AKI (Anti-Knock Index) – Research Octane Number 91.
As always, the higher the octane the better… My question is: If you own one of the highest rated performance sedans (in many cases THE highest rated), why would you put sh!tty fuel in it?
#48
magnetism80
02-01-2019 10:00 AM
Rhinos7777
09-06-2015 05:36 PM
