ecu reseting question
Old Jun 29, 2005 | 10:05 AM
Jeff Flowerday's Avatar
Originally Posted by G35_coupe_6MT
I have an 05, and tried doing this on my 04 (did not work):
G35 ECU Reset #1
1) Turn ignition on, wait 3 seconds
2) Push fully and release the gas pedal 5 times within 5 seconds
3) Wait 7 secs, fully push gas pedal and hold for 10 seconds until the CES light starts to blink
4) Release gas pedal (you are in diagnostic test mode 2)
5) Press and hold gas pedal for more than 10 seconds. Release pedal.
6) The CES light will continue to blink
7) Turn ignition off. Restart car.
What part did I do wrong? I got this from https://g35driver.com/forums/faq-diy/6538-ecu-resets.html
6MT:
Radio off.
Climate Control completely off.
Sunroof, windows and doors closed.
Parking brake on.
Clutch pressed when doing the procedure.
Don't do the 5 times in 5 seconds too fast.
Old Jun 29, 2005 | 10:18 AM
cato's Avatar
SouthernComfort Moderator
If your G seems sluggish, then yes, resetting the ECU probably will bring it back to life. The pedal method works. Also the method of removing both + and neg battery cables, then touching them togeather for 10 seconds works. Try it and bring the near dead back to life!
Old Jun 29, 2005 | 11:10 AM
rage777's Avatar
I tried to do an ecu reset with my 04.5, but couldn't get it. I tried about five times and nothing. I have read all the posts about turning off everything, using the clock on a CD, use a watch, jump up and down and yell, scream at the top of your lungs while doing a reset, etc. None of it has worked. I also tried that one where the guy said to remove the fuse in the engine bay and the one in the fuse panel inside the car, try to start the engine, etc. but that one didn't work either. I might just drive to Technosquare and get an ecu upgrade from them.
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Silver tiburon
Sep 4, 2015 07:17 PM
mrxkenny
Aug 17, 2015 05:52 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kenthung
Jul 21, 2015 05:56 AM
