suspension question
Old Jun 28, 2005 | 12:09 AM
g35guy86's Avatar
suspension question
if i got a Eibach Pro Kit is that all i need is the springs? or do i have to get new struts too?
Old Jun 28, 2005 | 02:48 AM
skeleton_cru's Avatar
Sedan
You can install just the springs.
Old Jun 28, 2005 | 03:39 AM
iche64's Avatar
How about G35x ?? >.<... I want to lowering my G35x too !! anyone has any idea that i can lowering my G35x ?
Old Jun 28, 2005 | 01:34 PM
socalsean's Avatar
It's a good idea to install stiffer struts along with lowering springs. The lower height of the springs might allow the strut to bottom out in its range of movement under extreme conditions. A stiffer dampner will be more difficult to bottom out. And since you're taing apart the suspension to install the springs you might as well upgrade the struts if you have the funds available.
sean
Old Jun 29, 2005 | 12:38 PM
g35guy86's Avatar
what struts would u guys recomend?
because im not sure if struts will affect the smoothness but if it does i dont want a hard hard ride.
Old Jul 5, 2005 | 03:22 PM
Triple8Sol's Avatar
IM), if you're going w/aftermarket springs, you need aftermarket shocks/struts too.
Old Jul 5, 2005 | 04:19 PM
shodog's Avatar
The struts and shocks from stock sport suspension are made by Tokico. So in essence they are aftermarket from the start.
Old Jul 5, 2005 | 08:58 PM
Gsedan35's Avatar
You have no option's concerning aftermarket shocks or coilovers do to the fact that your X uses a different front suspension design. You can use aftermarket lowering springs. Keep in mind that your car is supposed to ride .4" higher then RWD sedan's, you may get a greater amount of drop if you do use aftermarket RWD sedan springs. We do have a few member's with a G35X that have installed lowering springs.
Old Jul 5, 2005 | 09:10 PM
Gsedan35's Avatar
Well,......they are spec'd by Infiniti and not by Tokico's R&D staff. Plus those specs include cost cutting realities that compromise what they are able to deliver to your driving experience, meaning their is ample room for aftermarket offerings to deliver a much better product..
The D-specs have larger piston diameters, larger bodies, are double adjustable and feature vastly superior valving that when experienced first hand will be one item that you do not have to search for reason's why you paid money for them. I've helped two different member's install them on their G35's, they are well worth the cost.
Old Jul 5, 2005 | 09:12 PM
SGT's Avatar
SGT
Will there be any detrimental effects if aftermarket springs are used on the X?
Old Jul 5, 2005 | 09:45 PM
dklau33's Avatar
Depends on what springs you are using. Linear or progressive? Little drop or big drop? Stiff or soft spring rates?
Old Jul 5, 2005 | 09:53 PM
Gsedan35's Avatar
Hmm. What suspension does you sedan have?
Sedan prokit's were R&D'd on a non sport sedan. But that's not to say that even when paired with sport suspension shocks that you won't get more yawing and pitching then if you'd made a different spring choice.
Old Jul 5, 2005 | 10:10 PM
SGT's Avatar
SGT
I'm contemplating on using the Eibach Pro Kit, which I believe is progressive. I don't know much about springs and how they affect performance, but I'd like to lower the X by about 1-1.5". I don't want to compromise the ride quality. This will be in conjunction with a set of 18 wheels that I plan to get (when I get my G in a few months).
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
