View Poll Results: What method did you use?
Follow the manual and not exceed 4k RPMs.
56
58.95%
Drive it like you stole it.
21
22.11%
9.47%
Something else. Please explain.
9.47%
Voters: 95. You may not vote on this poll
How did you break-in your G?
Old Jun 30, 2005 | 10:27 AM
SGT's Avatar
SGT
Because there's so much controversy over which method works best when breaking in a new car, I'd like to find out which method the majority of people used. I'll be getting a new G, most likely the '06, in a few months and I'm not sure how I should break it in.
Old Jun 30, 2005 | 10:30 AM
GeeWillikers's Avatar
Walking The Fine Line...
As your tagline says, be a man, do the right thing.
I followed the manual. Think I broke 4K twice during the first 1200, and not by much. I was learning to anticipate the manual-shift mode of my auto.
Plenty of time to rev high later.
Old Jun 30, 2005 | 02:09 PM
MrBig's Avatar
It works on my machine
I to followed the manual. I only went past 4K once or twice, and very limited highway driving.
Old Jun 30, 2005 | 02:51 PM
harley01's Avatar
yup, followed the manual. You will get good at hitting the 4k mark. One time I pressed a little harder and she hit 4K REALLY fast....I was able to let off just as I passed the 4K mark.
Old Jun 30, 2005 | 02:59 PM
G35Alex's Avatar
I drove it like I stole it.
Old Jun 30, 2005 | 03:09 PM
SGT's Avatar
SGT
Doesn't it make you guys wonder what would've happened if you broke-in your G more aggressively? Reading Motoman's website got me thinking because he does give valid reasons. It seems as though the majority followed the manual, but for those complaining about how sluggish their G's feel in comparison to the loaners, isn't there a possibility that a hard break-in would be of greater benefit than a mellow one?
Old Jun 30, 2005 | 03:22 PM
byount's Avatar
Broke in progressively from 600 to 1200 miles.
Old Jun 30, 2005 | 03:39 PM
Nickk6's Avatar
Followed the manual this time, my last nissan went kablooey at 37k miles and I ripped on it 2 times during break in. This car hit 5000 rpm on about 3 occasions at 1/4 throttle. The engine was tight for about 2,500 miles, it has 8,600 and is much smoother and more powerful now.
Does anyone elses engine make a rattling metalic sound when they turn the ignition off. It sounds like the oil is low and all the valves in the head are rattling around. Oil level is fine and car runs great, should I not worry?
Old Jun 30, 2005 | 03:42 PM
doogie's Avatar
I too drove the **** out of it. No problems so far at 30K miles and it's stronger than ever.
Old Jun 30, 2005 | 03:44 PM
what2do's Avatar
You sure it's not the heat shield cooling down? It is making the same sound while the engine is on, but you can not hear it until you shut off the enginer.
Old Jun 30, 2005 | 03:45 PM
cato's Avatar
SouthernComfort Moderator
I bought mine when it came off a one year lease with 18K miles. I'm sure the aHole who had the lease drove the hell out of it! She hauls a**
Old Jun 30, 2005 | 04:00 PM
JSlodown's Avatar
I babied it for just over 400 miles and started revving more and more until 1000 miles. I have been launching to between 6 and 7k quite often now around 1500 miles and gaddam she's fast. I calculated about 1,000,000 cycles at 400 miles which I think is enough to achieve the required deformation on all engine break in parts. That, and I really couldn't wait any longer to hammer it....
Old Jun 30, 2005 | 04:17 PM
Corgidog's Avatar
I figured there must be a reason why Infiniti says 1200 miles so that is what I did. All things being equal (which they usually aren't), the engineers at Infiniti know more about break in than the avg. Joe on this board, myself included.
Old Jun 30, 2005 | 04:27 PM
Nickk6's Avatar
No, the noise only occurs right as the ignition is turned off and the engine spins its last few cycles before haulting. It just sounds like something is loose in the head, I don't remember the VQ in my Maxima ever doing that.
Old Jun 30, 2005 | 04:44 PM
MrBig's Avatar
Do you have your foot on the clutch or off? If it off then i read a post about the fork (or something like that) for the clutch rattles when idling, shutting off etc... And the dealer said it was normal. Mine does the same thing though.
