How to calibrate spedo for wheel change
Old Sep 20, 2005 | 11:32 AM
tonyj's Avatar
Anyone who has changed to different size wheels
Might be changing wheels for the upcoming winter, if they fit (17" aftermarket wheels I had on a 01 Accord). Is there any way to change the calibration setting so my speedo and odo read correctly when changing from 18" to 17"? What have you guys done?
Old Sep 21, 2005 | 12:27 PM
tonyj's Avatar
Come on, anyone out there????
Old Sep 21, 2005 | 01:27 PM
spendgy's Avatar
You can go to the dealer to have them reprogram. I'm not sure if there are any aftermarket solutions available.
apintojr's Avatar
i beleive as long as the overall diameter of the wheel is close to stock, you shouldnt have a problem.
Old Sep 21, 2005 | 03:07 PM
g35guy86's Avatar
yea i went with aftermarket 18s which were 29.5 in diameter and the stock 17s are 26.3 in diameter and it mybe changed my speedo 1mph at most.
Old Sep 21, 2005 | 03:29 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
I assume that's a typo.
=26.5 ?
Old Sep 22, 2005 | 02:39 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
Go to tires.com and click on the infocenter at the top. then go to tire dimensions and put in your tire size. it'll tell you the difference in circumference sidewall and diff speeds. hope it helps you. you could get a technosquare ecu too.
Old Sep 22, 2005 | 07:22 AM
PRMax's Avatar
http://www.miata.net/garage/tirecalcold.html
Old Sep 22, 2005 | 08:16 AM
GEE35FX's Avatar
Tony..as long as you get a tire that is close to the same diameter of your regular tires you will be fine.
For example I have changed from 215/55R17 to 235/45R/18 and according to my GPS my speedo is less than 1mph out at 60mph.
In the winter My snows are 215/60R16 and the speedo error is still very minimal since the diameters are all very close to each other.
As to your question about recalibrating, I don't know about these cars, but years ago I recorrected the speedo on my old muscle cars by changing the speedometer pinion gear.
Xfactor
Dec 1, 2019 12:52 PM
mcneil_g35
Aug 5, 2015 12:03 PM
kinetek
Aug 3, 2015 04:25 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
atk08
Jul 30, 2015 03:12 PM
