Mobil1 5W-30. This is the syn oil my dealership uses for their synthetic oil changes (about $80). I bring my own $20 (or so), 5 quart jug and just pay labor.
QuadCam said "I have no idea what Infiniti uses. I bet it varies from dealer to dealer."
Heck, it varies from service to service. I go to the same dealer every time, and they've used 4 different brands for 5 changes. Mobil, Pennziol, Castrol, and Havoline if I remember right.
factory oil is a xW40
Originally Posted by RocketsRedGlare
QuadCam said "I have no idea what Infiniti uses. I bet it varies from dealer to dealer."Heck, it varies from service to service. I go to the same dealer every time, and they've used 4 different brands for 5 changes. Mobil, Pennziol, Castrol, and Havoline if I remember right.
Quote:
I use Castrol Syn, and have for years. I love it. Originally Posted by erikill
Seems like no one uses Castrol Syntec, any reason? I was planning to change my oil soon 750 miles or so just to get the junk outta the engine. I think 10-30 Syntec Blend then to 5-30 Syntec is a good route. I've never been a Mobil fan for some reason.
I have used 5W30 and 5W50 depending on availability, but have avoided the '50' in the winter months.
I stick with the OEM filter.
Colin.
Quote:
That's what I did before with my Maxima and what I plan to do now also, take my own oil just pay them for the labor.Originally Posted by lelg35
It works on my machine
I don't want be a thread hijacker (I'll post another thread if wanted), but I have question for those of you who do you own oil changes, where do you get the drain plug washer and how often do you change it.
Is 5W-30 recommended?
Also, where do you get Amsoil in the northeast (Philadelphia area?) Any major stores carry it?
I use AMSOIL 5W30. I will recommend anyone to NOT go over 5k of miles with Mobil 1 because tests have shown on this engine it basically falls apart after 5k. Amsoil you are safe for more than 5k.
Quote:
I get mine from the nissan dealer..... you can get them at any Infiniti dealers also.... Cost is $1.25 each...I thinkOriginally Posted by MrBig
Quote:
Some will give them to you for free. Nissan dealers have them also. I just use a Fumoto valve, that solves the washer problem.Originally Posted by SilverII
Quote:
How does that work out for you? Any probs with leaking or anything?Originally Posted by socalg35
Quote:
That hasn't been my experience Russ. I'm running 6-7k mile intervals on Mobil 1 5W-30 and my blackstone reports are very good. Here is the proof, my reports are under "admin":Originally Posted by G35_TX
blackstone reports
Quote:
Agreed! I change mine every 3K. My drive to work is only 2 miles and I do a lot of short drives in and around town. Changed to Amsoil after 3K on car. Little more expensive, but I believe worth the price.Originally Posted by bythabay
Amsoil HDD 5w30 all the way...
