rear sub rattles?
Old Oct 15, 2005 | 11:54 AM
Andyl's Avatar
rear sub rattles?
does anyone else have the back deck rattle on certian songs when the bass hits? If so has anyone figured out what it is and have you stoped it? Post the cure if you know thanks Andy
Old Oct 15, 2005 | 09:45 PM
RetAF's Avatar
Mine sounds a bit mushy, but no rattles.
Old Oct 16, 2005 | 01:10 AM
anish3232's Avatar
I had this problem, then I got a Real Sub, but to get this fix take off the grill slowly it can break easliy and stuff around the sub with foam or watever you can find.
Old Oct 16, 2005 | 02:31 AM
aequitask's Avatar
i just noticed my '05 bass starts to rattle like 3 days ago
ill see how bad it is...might take it to the dealer
Old Oct 16, 2005 | 01:43 PM
Augy's Avatar
Does anybody have a diagram or know how to remove the rear panel where the sub sits?
Old Oct 16, 2005 | 08:44 PM
jimmyc13's Avatar
I know there's a TSB for this (not sure if it's for your '05 too or not)...but it wouldn't hurt to try. You can access the panel from your trunk...I'm guessing the '04 & '05 trunks are the same...there are 7 push pin/clips holding it up....all you need is a small flathead screwdriver.
Old Oct 22, 2005 | 05:48 AM
ydlee24's Avatar
Replaced stock sub with kicker compvr 8" used as free air with whole bunch of dynamat extreme on rear deck and dash and behind rear seats and cover for under the sub in trunk with poly fill. Absolutly no rattle at all when bass hits. I have JL audio 6.5 xr series in front and JL 5.25 xr in rear with kicker compvr 8 sub ran from a jl audio 6 channel amp.
Old Oct 22, 2005 | 06:44 AM
dkhuynh's Avatar
i took my car in for music rattles, all fixed with a free car wash and interior clean
tiguy99
Mar 1, 2016 11:42 AM
wuppiedog
Aug 7, 2015 11:16 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
kinetek
Aug 3, 2015 04:25 PM
Frostbite91
Aug 2, 2015 04:59 PM
