Cracked Taillight Lens on 05 G35x
Nov 11, 2005 | 09:34 AM
Anyone know what the plastic taillight assembly (just the cover) runs? Who may have the best price?
I had the misfortune of having a baseball bounce off one of mine.
George
Reply 0
Nov 11, 2005 | 09:37 AM
Quote: Anyone know what the plastic taillight assembly (just the cover) runs? Who may have the best price?
George
Try and glue it back together if you can so it's at least it looks like it's all one piece from afar, and the go test drive a new one and swap them
The dealer is going to charge the #### out of you, so perhaps a crap-yard might have one as well. DOT approved LED light housings are very expensive.
Reply 0
Nov 11, 2005 | 10:01 AM
George
Claim it on your comprehensive insurance, that's what that's for! Those claims don't count against you! Those come as a unit I believe, so they are expensive!
Reply 0
Nov 11, 2005 | 11:34 AM
George
http://www.infiniti-parts.com
this site pretty much has anything you would need that is oem. and good prices too. hope is helps.
they sell just the casing like you need.
Reply 0
Nov 11, 2005 | 08:43 PM
I have an 03 rear light set I will sell you for cheap if you want to change everything out
Other than that, ive only seen the lights sold as a set. Call you local dealer, they should be able to tell you if they can order just one or not.
Reply 0
Nov 11, 2005 | 10:34 PM
Quote: Try and glue it back together if you can so it's at least it looks like it's all one piece from afar, and the go test drive a new one and swap them
Hope you're not serious about the swap...
Reply 0
Nov 11, 2005 | 11:22 PM
That's not bad at all, I thought that would cost much more than that, those prices are good. Is it hard to change out a unit like that and not have it leak?
Reply 0
Nov 12, 2005 | 12:28 AM
Looks like infiniti-parts has it for $200?
Anyway, for the original poster, I'm willing to buy that cracked taillight off of you if you're willing.
Reply 0
Nov 12, 2005 | 11:48 AM
Try eBay
Reply 0
Nov 12, 2005 | 08:41 PM
Quote: Is it hard to change out a unit like that and not have it leak?
I've had mine on for almost a year now (installed the 2005 rear lights) and haven't had any leaks what so ever. As long as you make sure the area the seal sits is clean, your all good. Tighten the bolts down good for a nice tight seal.
Piece o pie!
Reply 0
Nov 16, 2005 | 09:55 PM
I've decided to leave it the way it is now. Others haven't even noticed it when I've told them about it.
Thank you all for your assistance.
George K.
Reply 0
