Tire pressure sensor came on again
Old Nov 13, 2005 | 10:32 PM
basus's Avatar
First came on last Monday and i filled gas on tuesday and went off , it was good because the tires had low pressure
Came on again this sunday morning , wtf is going on
I need to check the pressure again tomorrow but what could be the reason , unless theres a leak it cannot fall below within 5 days , again if there was a leak would not the tire become flat by now
Anyone faced this issue
Old Nov 13, 2005 | 11:59 PM
perry05G35's Avatar
Your Valve stems may need to be replaced.
Old Nov 14, 2005 | 01:22 AM
basus's Avatar
Do u mean that the valve stems are causing the leak , if so will the dealer replace it
Old Nov 14, 2005 | 04:18 PM
Msedanman's Avatar
O.F. Administrator
It's quite possible that there's a leak.....you'll have to check each tire's pressure again.
Another way pressures change is by air temp change.
If the pressures are all correct and the low pressure alarm persists, have the dealer reset it for you.
C.
Old Nov 15, 2005 | 11:48 AM
maller's Avatar
Could it be the temperature? It's getting to be that time of year where the nights can start getting cold. Maybe that's changing the pressure, triggering the sensor.
Old Nov 15, 2005 | 12:16 PM
basus's Avatar
Thanks guys
It was a leak as there was a nail in the tire, had it fixed , lets see how it behaves
Thanks
Old Nov 15, 2005 | 01:34 PM
SilverII's Avatar
Thanks guys
Thanks
Aren't you grad you had the sensors????? I bet it saved you from having to change the tire at the side of the road
Old Nov 15, 2005 | 02:01 PM
yamashirod's Avatar
I check my tires weekly and found one rear tire had slightly less pressure than the others. And would you believe it, there is a nail in it. Need to get it fixed. Those sensors work!
Old Nov 15, 2005 | 06:47 PM
basus's Avatar
Yes very glad that those sensors work
Old Nov 15, 2005 | 06:51 PM
ScottR's Avatar
Having the same problem, mine only comes on after about 50 or so miles. I check the pressure at least twice a week, never off by more than .5 lbs.? I had a Nissan Titan before and it did the same thing, wierd.
Old Nov 15, 2005 | 07:53 PM
basus's Avatar
You must have some sensor issues, wht did u do with the Nissan Titan where the same problem was there
jsimonk
Dec 22, 2023 03:49 PM
Muski_G
Dec 1, 2023 11:11 AM
joedaddy1
Jul 28, 2015 02:58 PM
stay_tuned
Jul 21, 2015 07:09 PM
