Clutch question...should I be worried?!?!
Old Dec 3, 2005 | 09:57 PM
Gthree5 6MT's Avatar
Gave the car a rinse off tonite...decided to "air dry" if y'know what I mean.
Felt a little immature, so turned off VDC and did a few launches. It was fun, until...
On the 3rd or 4th launch...I was redlined in 1st and I shifted into 2nd. Then, the unexpected/unimaginable happened - the clutch gave out! What I mean is, the pedal felt like there wasn't anything attached to it & the car wasn't moving anymore despite my reving of the engine!!!
I was like, "NO WAY!!!" The car only has 12,800 miles on it & I don't abuse it much.
After a couple seconds of shock & dumbfoundedness...I turned the VDC back on & put the car in gear again. It drove fine after that. Of course, when I got back, the car reaked of toasted clutch.
So...should I be worried? Is that normal? Has anyone else experienced this?
Like I said, the car only has about 12,800 miles on it & I don't launch it like that much....so, I highly doubt that the clutch is already worn out...RIGHT?!?!
Any feedback would be highly appreciated...Thanks!!!
Old Dec 3, 2005 | 10:08 PM
jawjaw's Avatar
Clutch wear could be from just over use and not just abuse. For instance, if you keep the clutch in halfway to balance on a hill, you are wearing the clutch. If you have an AWD G35, the clutch might slip more easily since there is more traction. When I rev it up between shifts, I shift very quickly and don't notice any burnt clutch odors. If you car drives okay, then it's probably fine just with a little less clutch.
Old Dec 4, 2005 | 12:23 AM
skeleton_cru's Avatar
Sedan
Old Dec 4, 2005 | 03:25 PM
dbarnes's Avatar
AWD G35 (aka G35x) is not offered with a manual transmission option.
Old Dec 4, 2005 | 03:54 PM
QuadCam's Avatar
i had the same thing happen to me ....twice! and my '05 has only 7xxx miles on it. This is unacceptable for this crappy a$$ clutch. i'm looking for a new one...one that I can have my fun with!
Old Dec 4, 2005 | 08:49 PM
trebien's Avatar
In my opinion, it's nearly imposibble to have a slipping a clutch in an AWD G35.
Old Dec 4, 2005 | 08:58 PM
vodkarocket's Avatar
Modded Member
It is impossible. The G35x has no clutch!!!
Old Dec 4, 2005 | 09:38 PM
jawjaw's Avatar
lol - I'm so stupid.
Old Dec 4, 2005 | 11:25 PM
trey.hutcheson's Avatar
++1
^^^Sorry
That was directed at vodkarocket, not jawjaw
No, really
Old Dec 5, 2005 | 02:02 AM
Modded Member
What did I do?
jeffbdye
Jun 1, 2018 03:51 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DRG35R
Jan 31, 2016 07:14 AM
AL8782
Oct 3, 2015 10:26 AM
Learned Hand
Oct 1, 2015 09:02 AM
