A/C econ?
Old Aug 5, 2003 | 05:56 PM
Real240's Avatar
A/C econ?
Just picked up my G35. It is my understanding that "Auto A/C econ" saves gas by using the A/C less, but it is locked onto "outside air" in that position. I would think that recirculation would save more energy because the air is already cool. Am I missing something?
Old Aug 5, 2003 | 08:06 PM
slinkyboi5's Avatar
Re: A/C econ?
It will automaticlly go into either outside-air or recirculate on either Econ or standard AC. My Econ AC uses the recirc. mode when it is very hot, but only until the car cools considerably, then switches to outside air.
Old Aug 6, 2003 | 12:08 AM
Rumble's Avatar
Re: A/C econ?
Does anyone find that their cars blows out a lot of warm air even when turned down to the lowest temp setting (when A/C is off)? Everytime I do not need the A/C and want to open the windows, there is warm air blowing out. I usual just shut the whole thing off and let fresh air cool the cabin. Is this a defect in my cars production? Any comments or suggestions?
It's still a G thang!!
Old Aug 6, 2003 | 12:25 AM
FDNameBrands's Avatar
Re: A/C econ?
Happens to me too. When it’s about 70° or so and I just want cool air from the outside to come in through the vents, it comes out hot and muggy. I guess its cuz the A/C external air intake is in the engine bay and sucks in the hot air from there.
Old Aug 6, 2003 | 02:19 PM
BobP's Avatar
Re: A/C econ?
With the A/C off, it blows a little higher temp because of the original setting; 72, 74, etc. Try holding down the temp guage for a few seconds with the A/C off. It will adjust (even though you don't see it) down to 60. The incoming air should be cooler. When you turn the A/C on the next time, it will be set a 60. This is just a little trick I stumbled across.
<P ID="edit"><FONT class="small"><EM>Edited by BobP on 08/06/03 11:20 AM.</EM></FONT></P>
Old Aug 6, 2003 | 03:29 PM
BoneDaddy's Avatar
Re: A/C econ?
Check the FAQ/DIY section. There is some good information on why hot air makes its way into the cabin. I am going to show it to my service guy and see if he has heard about it yet. Air that warm should NOT be blowing in on vent, no way.
[i]<font color=red>BoneDaddy
2003.5 Garnet Fire, Premium, Aero, Sport & Debadged
G35Rican
Jul 31, 2024 01:37 AM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
JLee301
Sep 25, 2015 08:46 PM
mattdg35
Sep 14, 2015 11:28 AM
