ISO Thermal Plenum on 2005+ NON-REVUP...
Old Dec 21, 2005 | 12:31 PM
4DOORFUN's Avatar
Are there are any 2005 or 2006 AT Sedans with the ISO Thermal Plenum? I did a search, but most people that replied to previous posts had pre-2005 cars. I’m just curious about the gains for the NON-REVUP engine for 2005+ cars.
Old Dec 21, 2005 | 04:45 PM
codeflux's Avatar
ISO *gasket* is recommended for *any* G. it's the MREV mod that's for the REVUP engines only.
Old Dec 21, 2005 | 05:13 PM
4DOORFUN's Avatar
Please re-read my post.
Old Dec 23, 2005 | 12:35 AM
nuttyprof's Avatar
whats a REVUP engine? damn...im soo out of the loop.
Old Dec 23, 2005 | 01:30 AM
Andy2434's Avatar
Were you referring to Motordyne's "ISO Thermal Plenum Spacer" or the "ISO Thermal Upgrade"? Checkout the following for more info . . .
http://www.motordyneengineering.com/G35.asp
The '05 G35's came with RevUp engine not the other.
Old Dec 23, 2005 | 01:31 AM
Andy2434's Avatar
The RevUp motors are the 298 HP motors, which are in the '05+ G's equipped with a 6MT.
Old Dec 23, 2005 | 11:37 PM
Oggie's Avatar
If you look me up, I have posted with info on my 05 G35x AT Sedan. The MD Spacer definitely works. Buttdyno indicates good gains from the Spacer. If combined with Z-tube and K&N, the benefits are even more noticible. My friend with a 05 G35 Coupe 6MT even felt my car is pulling harder than his car. Furthermore, the ISO Thermo feature is pretty good too since the penlum runs much cooler than before. Cooler means keeping hp even in a hot summer.
Old Dec 24, 2005 | 01:46 AM
4DOORFUN's Avatar
So it seems few people have added this mod to their AT 2005 G35's so far? Maybe my question is premature.
Old Dec 24, 2005 | 07:33 AM
grizzly's Avatar
me thinks the problem is in the way your question is worded... as others have pointed out, when you say "ISO Thermal Plenum?" people who have done the research are gonna think "huh? you don't need the MREV Plenum for an AT!"
Assuming you mean the Plenum Spacer, then this is your answer:
Originally Posted by Hydrazine
Originally Posted by speedgeek
05 AT's have the origial motor (unlike the 05 6mt w/ 298hp), so the spacer has show good results on the NON 298hp motor.
Its been dynoed on that plenum configuration many times. ...Between 8-13 HP and typically above 10.
see 3/8" Motordyne Spacer Review
oh & you probably woulda got a lot more responses if you didn't restrict your question to Sedans. The gains are the same for AT Coupes, and the Coupe crowd is a lot more mod adventerous...
bottom line: buy the dern thing!
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
