DIY 2003/2004 G35 Sedan rattle exorcism
Old Mar 28, 2010 | 12:45 PM
  #91
Hossmaxima's Avatar
Does anyone hear have noise coming out of there rear passenger window, sounds like the windows open but it not.
Old Aug 12, 2010 | 04:00 PM
  #92
Abax84's Avatar
Is there anyway to "revive" this thread? Meaning the images.. The hosting account must be long gone, but the instructions are intended to go along with the now missing images. Can we do something about this? I am offering to do any image hosting needed. Perhaps a moderator should look into an image hosting account to ensure stickied threads don't lose images..
Old Aug 12, 2010 | 04:10 PM
  #93
RicoG35x's Avatar
DaveB is still alive and doing very well on G35Driver... it's just this post is over 5 years old.... so who KNOWS what site he posted the pics on.. in Internet time 5 years may as well be 500 years... most of his current stuff is on photobucket.. send him a PM... and ask nice..
Old Aug 12, 2010 | 04:21 PM
  #94
VEEG35.0's Avatar
ya that would be nice to see the pics
thanks for the help
Old Aug 12, 2010 | 05:07 PM
  #95
Abax84's Avatar
Yeah I know Dave is still alive lol I was referring to the images specifically haha.. I was going to send him a pm but thought it might be worthwhile to first see if the images could be restored and in turn, the thread. To keep us from filling up Dave's inbox.
Old Aug 15, 2010 | 03:17 PM
  #96
B T's Avatar
B T
awesome, i had to listen to a damn squeak from the door panels all the way from Mobile, Alabama to Houston, this **** is getting fixed before the return
Old Aug 16, 2010 | 02:17 PM
  #97
DaveB's Avatar
All the pics should work now. Essentially, if you hear a squeak or rattle, mark it on the face of the panel with a piece of tape, remove the panel, and start looking around for the culprit in the general area where your tape marker is. Almost everytime, it's a piece of hard plastic taping a metal part of the chassis.
Old Aug 17, 2010 | 12:12 PM
  #98
Abax84's Avatar
^Thanks Dave.. I know what ill be doing this weekend now..
Old Aug 18, 2010 | 11:01 AM
  #99
crroach71's Avatar
B Pillar buzz - near seat belt height adjuster - or so I thought
I have read through this thread twenty times trying to find a solution to this buzzing noise I have chased for weeks. Its right in the drivers left ear, near the seat belt height adjuster in the B Pillar. After several forays into the B Pillar area, felt taping anything I could think of, I finally determined that the noise has been eminating from where the arm rest on the rear drivers side door attaches, up near the handle. The two different leather materials rubbing together were making the sound (a phenomonen I have noticed throughout the vehicle). I was able to put a small shot of lubricant (suggest something heaver than WD40 that won't evaporate over time) in the gap, and the noise is now totally gone.
Just wanted to contribute.
Old Aug 19, 2010 | 09:40 PM
  #100
Eno's Avatar
Eno
Wish I could contribute with a solution but so far all I have is a location of a trouble spot. I do have BC Coilovers- but I'm not convinced that's what's causing it. My problem sounds like a knocking just outside of the child seat anchor location, right up against where the rear deck meets the B pillar. The reason I troubleshot my coilovers is because it's the exact location of where the shock tube attaches to the car that is making the racket. Coincidence? Anyone else had this problem?
Thought it might just be the seat itself- but the shaking the seat makes a different sound. I put in some weather stripping anyway just to see if it could buffer but it didn't touch it. I also tried adjusting the spring tension on the coil on that side... but even adding an inch of tension didn't touch the problem either.
The sound seemed to have started with the installation of a sub behind the seat- and I'm starting to wonder if there's something back under the rear deck on that corner that had to be adjusted for the installation? I know taking that rear deck off is a nightmare... argh.
Old Jan 20, 2011 | 09:08 AM
  #101
N8boi's Avatar
so i have done a lil searching through this thread and others, and very well done DaveB, very helpful and awesome......great job!
but I couldnt find if anyone else has had the UPPER glove box rattle. pretty sure its the door on it cause when i press on the door the rattle stops so imma try some things but was curious if anyone else has found a solution for this rattle?????
Old Mar 6, 2011 | 04:44 AM
  #102
sch4400's Avatar
Great info. thanks for the info
Old Mar 6, 2011 | 12:11 PM
  #103
zeek's Avatar
Thank you thank you thank you for posting this. The squeak in my rear doors was driving me crazy! I followed this guide and TOTALLY fixed the squeaks. The car is silent now!
Old Dec 30, 2011 | 08:53 PM
  #104
2gnt2wrx's Avatar
Thank you for the thread, I recently took out the rear seats and went to town with some sticky felt. It got rid of a ton of rattles and a really bad squeak. Thanks again.
Old Jan 5, 2012 | 12:13 AM
  #105
MikeTanabe's Avatar
wow this Sedan rattle exorcism looks crazy...I will actually pay your gas+$ to come here an and help me lol But thanks alot for the write up!!!
