20X8.5 / 38mm Offset or 20x8.5 with 20mm
Old Feb 5, 2006 | 06:30 PM
Trini1976's Avatar
Hey I picked up my 03 sedan last week with the aero kit. The rims I'm looking at are 20x8.5 with a 38mm Offset. I plan on installing Eibach Pro Kit after I get the rims, would the 38mm offset be fine with the drop or should I go 20x8.5 with 20mm offset
Old Feb 5, 2006 | 06:49 PM
godmans's Avatar
the 20+ mm offset would never work for Sedans without a widebody kit or rolling your fender
Old Feb 5, 2006 | 06:52 PM
perry05G35's Avatar
Get the +38 it will be perfect. Chico has Pro Kits with 20" wheels I have Pro Kit with the 19"
Do a search on Chico to see pixs of his car with 20" Milanos and the pro kit springs I think he has a =38 offset as well.
Old Feb 5, 2006 | 07:09 PM
Trini1976's Avatar
Thanks for the info guys. I did not understand how it works
Old Feb 5, 2006 | 08:23 PM
godmans's Avatar
offset means how much your wheel tuck in or stick out (if you want a more thorough definition, you can try google wheel offsets and camber and those stuff). Generally, for a G sedan, depending on your rim width and the tire profile, the offset that you would be using ranges from +35 mm to +48 mm.
For instance, when you have a 18x8 rim with a low wall prfile tire of 245 width, you can go with a +38mm offset. However, for the same rim, but if the tire design has thick wall profile (same width 245mm), you are prolly going to need +45mm or +42 mm.
Hope this helps!
Picture Share
Feb 4, 2018 12:41 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
w4kj4k
Oct 2, 2015 07:57 PM
TurTLe*
Sep 29, 2015 01:43 PM
