What is a revup engine?
Old Feb 13, 2006 | 04:10 PM
perfpump's Avatar
Sorry to seem ignorant, trying to learn so I can get what's right for me! But what is a revup engine, and what is not??
Old Feb 13, 2006 | 04:19 PM
MikeyMike's Avatar
Rollin On Dubz
The G35 Rev-up engine is a 6 speed manual for years '05 and newer.
What is not is ANYTHING 03 and 04 models regardless of transmission, and ANYTHING that is Automatic transmission regardless of year.
Old Feb 13, 2006 | 04:24 PM
perfpump's Avatar
Thanks MikeyMike..... so my next question is, what can I do with this engine? I'm guessing rev-up the rpm's and pop the clutch? Is there any other significance associated with this engine? I've read about some mods with the plenum spacer and ECU, but am unclear as to whether these mods can be done on any engine, or just the rev-up.
Old Feb 13, 2006 | 04:29 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
The rev-up engine has more power (298) than all the others (266-280) but Infiniti sacrificed the low-end for more top end with the rev-up motors. The best mod for the rev-up motor is the new Motordyne MREV plus (lower plenum from pre 05-06 MT's and an iso thermal plenum spacer) it's said to gain near 20HP and 20Ft/Lbs TQ. The MREV can only be done on the rev-up motor. You can do the normal intake, exhaust, headers to the rev-up motor just as you can to any other car. Use the SEARCH function and you'll find plenty of info that you need on the rev-up motor.
-GP-
Old Feb 13, 2006 | 04:33 PM
Corgidog's Avatar
I don't know if I would categorize the 05/06 6 spd as a rev up engine as it really only has a redline just several hundred rpms higher. To me an example of a "rev up" engine is something like the Honda S2000 which has 240 horse and only 140 or so torque. this car has to rev real high to generate horsepower. Remember HP is rpms X torque divided by 5252.
Old Feb 13, 2006 | 05:02 PM
It's not really categorized as a rev up engine like the s2k. It's just infiniti's new name for the VQ35 6MT. Although if you think about it it's still kind of like the s2k motor. They bumped up the horsepower and left the torque therefore making it harder to produce big power down low. The VQ Rev-Up motor makes it's power in the higer RPM range just like the s2k motor.
-GP-
Old Feb 14, 2006 | 11:29 AM
perfpump's Avatar
Thanks for the insight. Now I understand what the term rev-up means! I haven't had a new car since the "ex" took my Grand Prix away from me 5 years ago. It was a crappy car anyway, but she took it and then promptly sold it! Now that she's long gone, this G35 will belong to nobody except ME!
Old Feb 14, 2006 | 11:37 AM
hayaku's Avatar
"rev-up" is the term nissan gave the newer 298hp engine. I think it came simply from "revision up" as in they made a revision to the motor. Variable valve timing was added to the exhaust valves, the intake plenum was revised, some of the ECU mapping was changed. I think even some of the conrods were strengthened. The result was an increase in HP: 18, and loss in 10 ft-lbs of torque. My basis of info is from the Nissan engineers that came to talk at the Turbonetics meet a few months back. Hope that helps.
Old Feb 14, 2006 | 12:59 PM
MrBillMartin's Avatar
for me its an increase of 38 more horsepower comming from the 260hp motor. and let me tell you, those 38 extra horses makes it a hell of alot more fun to drive.
Old Feb 14, 2006 | 01:53 PM
MikeyMike's Avatar
Rollin On Dubz
Definitely get the MREV mod. Everyone who's put it on their car has really liked the results.
Go to forums at the top, then go to SEARCH to find more info.
Old Feb 14, 2006 | 05:20 PM
FenixL1P's Avatar
the mrev+ plenum mod is up next on my mod list....do you think it's worth saving nearly 12 bucks in shipping to wait until everythingg35.com has it in stock?
If i can get it for $620 shipped, my wallet will be talking...
Old Feb 14, 2006 | 05:22 PM
e420x's Avatar
Mod Junky!
partshippersdave sent mine right away
Freeman186
Sep 6, 2023 10:07 AM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
AT23
Sep 15, 2015 07:44 PM
AuAltima3.5
Sep 13, 2015 10:53 AM
