sedan shock sensor alarm install
hi-anyone do the shock sensor mod from boosted concepts:
http://boostedconcepts.forumup.org/a...dconcepts.html
to a sedan?
did you use this red and white wire with dashs of silver?
(pointed out w/ green arrow above fuse box)
thanks in advance-
rob
to a sedan?
thanks in advance-
rob
You best bet would be to grab a voltage meter and test out the wire. You should never blindly hook any wires up to any wire in the G/Z. With all the communications lines that run through the car you have no idea what you could be tapping in to, unless you verify it with a volt meter!
Good luck!
Good luck!
stay_tuned
Jul 21, 2015 07:09 PM
