350z OEM springs
Mar 10, 2006 | 11:45 PM
How much do you think the OEM 350z springs will lower an 05 X? I am undecided as to which lowering springs I am going to be lowering my X with.
Reply 0
Mar 11, 2006 | 02:08 AM
Here is a G35 sedan(PDT's G) with 350Z springs(not an X, though)
Quote:
Originally Posted by Endless G
PDT, what are the spec? Offset?! Drop?!?
Thanks
HPD MSR in Hypersilver.
Front 19 x 8.5 offset +42
Rear 19 x 9.5 offset +40
I'm running the OEM 350Z springs all around so it's about an inch drop.
C MORE PICS in this thread:
https://g35driver.com/forums/g35-sedan-v35-2003-06/88459-i-want-see-deeeeep-dish-rear-rimz.html
Reply 0
Mar 11, 2006 | 03:35 AM
Indeed, from the pics (n from other users), I would say it would be
F: 1.3 inch
R: 1.6 inch
drop
Yet, for the X, since you have 0.5 inch higher to start with, you might
be looking at a 1.5 / 2.1 inch drop..
Reply 0
Mar 11, 2006 | 09:32 PM
I just Ordered a set of 06' OEM Z Springs ... As I understand They should lower a sedan 1" and since an X is .4" higher, an X would be lowered 1.4".
I'll let you know how it turns out
Reply 0
Mar 12, 2006 | 09:01 AM
As an owner of an 05X, I'm curious as to how this works out and what ride quality is like. I'd hate to lower the car and get a bouncy ride. Also, with no sport shock alternatives available for the X, we're stuck with the OEM struts. Another reason I haven't lowered mine yet. Let us X owners know the results please
Reply 0
Mar 12, 2006 | 11:05 AM
Yeah i think that I am going to go ahead and order these....Where is the cheapest place I can order these from?
Reply 0
Mar 12, 2006 | 11:26 AM
buy them off of a 350z at my350z.com. I got '05 struts with 500 miles on them for $130 shipped and springs for $50 shipped. you can find some good deals in the wanted/ private sales there.
Reply 0
Mar 12, 2006 | 12:40 PM
Quote: As an owner of an 05X, I'm curious as to how this works out and what ride quality is like. I'd hate to lower the car and get a bouncy ride. Also, with no sport shock alternatives available for the X, we're stuck with the OEM struts. Another reason I haven't lowered mine yet. Let us X owners know the results please
Remeber to buy 04.5 + REVISED 350Z springs ! Good luck
Reply 0
Mar 12, 2006 | 02:45 PM
The bounce comes from the shocks. NOT from the springs.
Reply 0
Mar 12, 2006 | 03:02 PM
I am aware of that, thanks. I am just curious if the 350Z springs match up with the OEM struts. I'd hate to put the 350Z springs in and ruin my ride.
Reply 0
Mar 12, 2006 | 03:17 PM
This has probably been asked before. Are the 04.5+ springs a different color than the earlier ones?
Reply 0
Mar 12, 2006 | 04:48 PM
I also ordered mine from my350z classifieds .. and as I understand the 04.5+ springs are stiffer .. If you do a search, someone on this forum put the Z springs on his X and had good results.
I will get them installed in the next week or two ... anyone recommend a good place to get them installed in South Florida ?? (EXCEPT INFINITI OF COCONUT CREEK)
Reply 0
Mar 12, 2006 | 08:57 PM
The shocks and springs physically fit. However, the shocks will likely be trashed as they will bottom out. May bottom out.
Reply 0
Mar 12, 2006 | 09:05 PM
Quote: The bounce comes from the shocks. NOT from the springs.
Sorry for the wrong info =)
To correct myself, the 04.5+ revised springs and shocks should have
less bounching because of the revised design on the shocks. Moreover,
they stiffened the rear springs to a spring rate of 417
Reply 0
Mar 12, 2006 | 09:08 PM
And they are linear spring too!!!!
Reply 0
