5AT Question
Originally Posted by DaveB
I've driven both systems and to my surprise, I actually like the earlier "top gear limiter" setup. I like the fact that I have total control of manual mode, even from a stop. I found it annoying that when you're in MM an 04.5 and above, it always requires you to do all the shifting from the stop. It seemed like a lot of work. I like the fact that with my 03 I click it over to MM at a stop and I can tell the tranny exactly what gear I want it to shift up too or I can hold any gear I want.
One thing I do like about the 04.5+ tranny is that it's very responsive. It rips off MM shifts, even the 1-2. A WOT 1-2 manual shift in my 03 is met with an annoying reduction in power as the car shifts into 2nd. I call it Torque Management (ie a system that reduces wear on a tranny under severe load). My friend's 03 sedan does the same thing. Oddly, when I let the tranny do it's own thing on the 1-2, it rips off the 1-2 shift. Sometimes it barks the tires. Weird.
Originally Posted by OCG35
A lot of work to tap the shifter up less than an inch??? 04.5 will hold any gear - it will only down shift when you drop below 600rmp - from any gear... I can be in 3rd and coast down to a crawl at 600rmp then accelerate and I will be in 3rd... of course it's foolish because the car will be gutless and bog till rmps are up... Personally I think the TCU and flexibility of shifting is best on 04.5 - it won’t up-shift or downshift unless I do it manually. The way it should be.
I can hold any gear I wish with my 03. I can place my car into 2nd and bang the limiter all day long if I wish. I hold 3rd at the track and often times bounce off the limiter just as I'm passing the finish line. I've never experienced upshifting in manual mode if I hit the limiter.
To me it does feel like a lot of work to have to be constantly shifting everytime I come to a stop. When I'm driving in town, I often leave my car in 3 or 4 (depending on traffic) which gives me a little engine braking instead of riding the brakes. With an 04.5, you would have to be shifting up to 3 or 4 everytime you come to a stop or slow roll. If I wanted to have to manually shift all the time I would have just bought a manual.
My experience with the 04.5 5AT is different than yours and so far I've had two 04.5s and one 05. I had always read about the 04.5 5AT holding gears, even at very low rpms, however I've never seen that happen in any of my loaners. If I have the tranny in 4 and I go around a turn at 10 mph, the tranny downshifts into 2nd and holds it until you manually shift up. I've never had the tranny hold 4th through a slow turn or a slow roll. It always downshifts to appropiate gear and then holds it until you upshift.
With that in mind, are 04.5+ able to do 2nd gear or 3rd gear starts?
DaveB - I don’t know why I'm even getting into this, but your post makes no sense... you state that you don’t want to shift gears in manual mode, that if you wanted to shift gears you would have bought a manual... just keep the damn thing in full auto! Manumatic is there for times when you WANT to shift!!! As for holding gears - I question whether the loaners you drove were 04 or 04.5 - It's hard for me to believe some 04.5 cars will do what mine does and others won't... this is my last post on it. By the way – have you noticed how sh!tty this site has gotten? It’s due to the BS that flies around here.
i completely agree. if you dont want to shift then keep it fully in "D" then you dont got to worry. The manumatic mode is for people who want to eat corners and play around and have fun or maybe track with the A/T.... dont like it then keep it in drive.
That's the way it should work
I can most certainly tell you that I've had two 04.5 loaners and one 05X. The 04.5s are dead giveaways because they have the newer and classier shift **** plus the shift gate is much shorter. I even popped the passenger kick plate off to look at the completely different TCU. And yes, the tranny selected 1st when coming to stops and forced me to upshift every gear. Also, I never got one of these cars to hold 3rd or 4th at anything below 1000rpms. When the rpms dropped down below 1100rpms or depending on load, the tranny will manually shift into the appropiate gear.
Originally Posted by DP03
I disagree with this. When would holding a gear down to 600 rpm's EVER be beneficial? I can't think of a situation. Next to high heat, bogging is the worst thing for a tranny and motor. My 05 downshifts to appropriate gears way before 600 rpms, but will not upshift until shifted.
You're not understanding me. I do use manual mode a lot, but rarely do I use to upshift when driving around town unless I'm rapping it out somewhere. Sometimes I'll use MM to downshift when coming up to a corner if I'm feeling frisky. The problem I have with the 04.5+ tranny is you always have to be working the upshifts. When I drive around town, I hit the shifter in MM and it defaults to 4 and holds 4th. With the 04.5+ you can't do this. You're forced to upshift every gear until you reach 4th and then if you're speed drops below an ideal speed, the tranny downshifts accordingly, again forcing you to upshift to 4th eventually. With my 03 I can leave it in 2, 3, 4, 5 and it will perform like an auto and will only shift up to the gear I select. If I want total control then I hit it into 1st and manually shift any gear I want. In the end, you have more control with the 03 tranny than what the 04.5 gives you.
You are wrong on two counts... the tranny will NOT drop to a lower gear unless you do it manually - unless you are under 600rmp (on my car), then it will drop to 1st gear no matter what gear you were in. That is the ONLY time it will drop gears on it's own. The second area where you are wrong is you were not looking at an 04.5 TCU unless you took the transmission apart - it is house inside.
As for the TCU on the 04.5 I looked at, I really have no idea what kind of device I was looking at, there is DEFINITELY an electronic box on the 04.5 in the same exact location as the TCU as the 03. The box on the 04.5 is significantly smaller and and doesn't have near the wire bundle coming out of it, but I cn assure you there is a device in the location. Look for yourself. It takes all of 1 minute to access.
