Speed at 3000 rpms???
Old May 10, 2006 | 10:22 PM
stl_ls1gto's Avatar
the X has a higher numerical diff ratio to help make up for the extra weight I believe. I also know that if you leave the shifter in MM, the convertor does not lock on my 05 X. If you leave the cruise on a certain speed, say 70 mph on the highway, then shift from drive to manual mode, and shift back from 4th to 5th since it drops to 4th automatically when you go to MM - it will register about 200-250 more RPM's in 5th gear when you are in MM vs. Auto.
KruZZe
Feb 27, 2023 05:04 PM
alessandro
Oct 8, 2015 09:29 AM
aaron3719
Sep 29, 2015 10:12 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
vamarris
Sep 26, 2015 12:56 PM
