Rpm Signal.
Old Mar 31, 2006 | 01:40 PM
killerlexus's Avatar
Rpm Signal.
where and which wire should i tap in to for a RPM activated window switch. i want to add a rpm on/off window switch to my NOS set up.
Old Mar 31, 2006 | 01:43 PM
DaveB's Avatar
You should be able to tap directly into the rpm wire of any of the six coil packs. I had an rpm switch on my Maxima that activated the intake manifold butterfly valves and we all tapped our switches into a coil pack.
Old Mar 31, 2006 | 05:00 PM
thanx buddy, but i was actually looking for the wire to tap in to off the computer, i dont want to run a wire throught the fire wall if i can avoid it.
Old Apr 1, 2006 | 12:22 AM
DaveB's Avatar
There is a wire, but you'll have to use the FSM to find it. I actually ran two rpm switches at one time (one for the valves, one for a shift light) and I had the shift light tapped into the ECU rpm wire. I did this because at the time I didn't know that I could have simply tapped the coil pack.
Old Apr 1, 2006 | 08:26 AM
KPierson's Avatar
The wires that go to the coil packs originate at the ECU under the passengers dash, so you can tap them there. At the ECU you can also find the crankshaft position sensor, the cam angle position signal, and all 6 fuel injector signals.
06g35
Feb 14, 2022 05:59 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
JustinMKN1
Sep 18, 2015 03:40 PM
