best offset for 19x8.5 with 255/35/19 rubber
Old Apr 7, 2006 | 12:48 PM
mrgags's Avatar
before i asked if a 255/35/19 tire would fit all the way around on the x. So i kinda got a answer for that. Here is my question now, what would be the best offset for this kind of setup. The thing is, I want my wheels to come pretty aligned with the fenders and am not sure what offset would be best. I appreciate all your help guys, Thanx!
Old Apr 7, 2006 | 06:15 PM
skeleton_cru's Avatar
Sedan
+40 mm offset will ensure you don't rub the fender with the 255 tires. I have +38 with 245 tires and I'm just a few mm away from rubbing the fender.
Old Apr 8, 2006 | 05:06 PM
mrgags's Avatar
another question, can i go 19x9.5 all the way around on an x
or will it rub or have other problems
I want to have a decent lip all the way around, atleast 2.5 to 3 inches
Thanx folks
Old Apr 9, 2006 | 05:17 PM
Sedan
Thanx folks
No, 9.5 is too wide for the front. 8.5 is the max.
Old Apr 9, 2006 | 09:48 PM
perry05G35's Avatar
255 all the way around you would be the first most stick with a 245 in the front that's the widest you can go but I don't know for sure if a 255 on a 8.5 wheel would cause rubbing I would say you would have to get at least a +35 if not a +33 to make sure you are putting enough of the wheel away from the suspension components
Old Apr 9, 2006 | 11:31 PM
Sedan
A +33 offset would most definitely rub the fender with a 255 tire (and a 245 tire). Please stop giving out advice about offsets if you don't know what you're talking about.
Edited because I did not see your reference to suspension components.
Old Apr 9, 2006 | 11:41 PM
G35_TX's Avatar
My 19x8.5 with 245 up front has more than enough clearance to go wider. 38mm offset.
Old Apr 10, 2006 | 02:39 AM
Sedan
Mine doesn't. I would probably rub with 255 tires. Remember, different tires have different sidewall shapes.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Picture Share
Feb 4, 2018 12:41 PM
dcsbh1
Oct 1, 2015 03:15 PM
TurTLe*
Sep 29, 2015 01:43 PM
