Tint Question....novice
Old Feb 18, 2005 | 08:59 PM
  #31
Drv4fun's Avatar
Wil,
Let me know when you guys start to use this new Madico film. I've talked to a couple local shops here in SoCal and still undecided as to which film to use.. (llumar, solar guard, etc.). Maybe when you guys are down here sometime in April, you can do a group tint for some G35 owners...
Old Feb 18, 2005 | 09:29 PM
  #32
Nickk6's Avatar
Thats 20% in the back and %35 in front. I had limo before so I went with lighter tone this time.
Old Feb 18, 2005 | 11:16 PM
  #33
vegasG35sedan's Avatar
05-G35 Sedan 5AT
Originally Posted by wil
Madico is coming out w/ their new high-end IR film (nano-technology film) that is to be used to compete w/ Huper and V-Kool. We will be testing this film next month for Madico and will be ready for sale in April. Cost will be in the neighborhood of $400-$490 depending on vehicle and number of windows. It will offer better heat reduction at a higher VLT (light transmission) percentage than even metallized limo tint. Another benefit to it is it will not disrupt radio, cell phone, and other wireless signals.
Probably the same as what I have. http://www.formulaone.com its the pinnacle series... nice stuff. I put the pinnacle15 on and it ran 350.00
Old Feb 19, 2005 | 06:04 AM
  #34
Premier's Avatar
We've seen the specs on the new Madico IR film and it offers excellent heat reduction........beats out metallized 5% tint by some 15% and is much lighter in shade (between 50%-75% VLT). In addition, Madico's adhesives are the clearest in the industry and have extended that to their new film as well.
After our NYC / NJ tour from March 25-April 3, we will be returning to socal in mid April. If you're (Drv4fun) interested in getting together w/ some G members here for a gb, let me know and I'll work something out for you guys.
Old Feb 19, 2005 | 10:48 AM
  #35
G35Alex's Avatar
All I can say is, on my xB, for the first time, I had Madico Charcool installed, full limo, and honestly, I was so impressed by the quality of tint. This time around, I won't do full limo, as you couldn't see a damn thing in the xB, but two thumbs up on Madico.
Old Feb 22, 2005 | 10:25 AM
  #36
BigBird's Avatar
Originally Posted by ABQ_G35
Wil, mine wasn't done that way, it was already tinted by the dealer, but since you know how to do it, perhaps you can recommend a way to clean the glass behind the brake light, I have tried many things, and all leave it less clean than I would like, I'd appreciate any suggestions.
Wil: I'm with ABQ. I would really appreciate you sharing how to tint the window (third brake light) properly. I'm guessing you don't want to reveal any "trade secrets", but it would be a great help and I would appreciate you reconsidering, if that's the case.
Also, now that my rear tint job is alreadry "done", can it be fixed, either by removing the old tint and starting over, or just "filling in" the brake light? There is some slight debris under the film, in addition to the off-square, irregular shaped cut-out around the light. When I asked about re-doing the back glass, I was told the tint couldn't be removed without messing up the rear defogger. I'm not sure I'm buying all of this.
All I want is a professional job. I didn't call around for the cheapest place; I went to a tint shop that I thought was highly recommended. Am I being too ****? What do you think?
Thanks for everyones input.
Old Feb 22, 2005 | 03:17 PM
  #37
Premier's Avatar
To clean that area behind the brake light, you would need to find something very thin and wrap it w/ a microfiber towel and just scrub away. Make sure to use a dry micro.......this should clean up whatever you have back there.
I am a window films trainer for Madico Window Films Asia. The information that we provide for these paying students is really exclusive for those enrolled in the courses, which is why I do not release installations information.....hope you understand.
As for your brake light area, it can't be "filled" in. If you decide to go and have them remove it and redo it, then they would definitely need to remove the rear deck bc they need full access to the glass in order to remove 100% of leftover adhesives. If there's even one speck of glue left behind, it will be very noticeable once the new film goes over it.........removing film and retinting w/ a new piece takes even more attention to detail than the first install. They would need to remove all adhesives along the dot matrix and defroster lines.......this would take about an hr including the rear deck removal.
The film can be removed w/o damaging the defroster lines. Unfortunately, companies usually say this to try and get away w/ not having to redo any install - it's a scare tactic. Films are not permanent and if any company tries to push this point, then they are trying to pull your leg.
BigBird, where are you located? I could, perhaps, check to see if we have any good contacts out in your area that could help you redo the rear.
Old Feb 22, 2005 | 03:27 PM
  #38
BigBird's Avatar
Thanks for your reply. I'm in northwest Arkansas.
So is there anyone out there who is not bound by "trade secrets", who will share their thoughts on how to tint the light area?
P.S. You know, I'm screwed. These guys wouldn't do it right the first time; they wouldn't fix it when I went back to ask them about it afterwards; and I seriously doubt anyone of us thinks they are going to go back and fix it right now either!
I guess I'm just hoping to show them that it could have been done right the first time and that they still could take care of it know. If they knew this before, then they are just being lazy and won't do anything about it now either. If, however, they sincerely did not know, then I'm hoping that they will come around and take enough pride in their work to go back and re-do it properly.
Old Feb 22, 2005 | 04:34 PM
  #39
KingoftheRoad1's Avatar
Originally Posted by roro
can anyone recommend a good tint shop in the north jersey/nyc area?
I know a very good one in Edison, is this too far for you?
Old Feb 22, 2005 | 09:50 PM
  #40
Premier's Avatar
What kind of film was used for the installation? Can you take some pics and post it here..........like to see how much cut out was done..........it's possible to get this redone w/o removing the rear deck depending on how large this cutout is.........can you take some multi-angle pics? Hopefully, I could help you with this.
Old Feb 22, 2005 | 10:04 PM
  #41
roro's Avatar
its not too far (less than an hour drive). if you highly recommend them then it'd be worth the drive. what's the name/address of the shop? and how strict are jersey cops about tinting front windows (nothing ridiculous... maybe like 50%)?
Old Feb 23, 2005 | 02:10 AM
  #42
G35STUD's Avatar
I have 5% all around and i payed $145 for it.... Isnt that a hook up boys...
Old Aug 10, 2005 | 10:18 AM
  #43
audiphile's Avatar
Anyone know of a shop in the Greenville, SC (or Charlotte, NC) area that can do a good tint job as it is seeming difficult to find anyone that does not find it necessary to cut out around the third brake.
Thanks for any input...
Old Aug 10, 2005 | 04:00 PM
  #44
bajracharya's Avatar
I have a Black sedan and I did Llumar (charcoal) 20 all around. Love it and I need it in the heat here in south Florida. Cost $130.
In my previous car, I had Llumar 30 front and 20 back and rear (and so is my wife's current SUV). Was good enough. The new 20 all around is even better.
R350k5
Lights
Jan 12, 2016 09:22 AM
c_elliott83
Sep 25, 2015 07:55 AM
Berncity1711
Sep 22, 2015 06:55 AM
