MP3 Capability
Old Apr 21, 2006 | 09:03 AM
ddenunzio's Avatar
MP3 Capability
I have an 03.5 G35 Sedan, I thought I read in the manual that the in dash changer does MP3 Cd's. I burned a couple discs to try it out and I get nothing. Disc shows up as one giant track. Any knowlege out there?
Thanks again.
Old Apr 21, 2006 | 12:40 PM
jimmyc13's Avatar
If you read your manual, you'll see that it doesn't support MP3's. The '05's and up do though (that sucks).
Old Apr 21, 2006 | 08:45 PM
jimNC's Avatar
What really sucks is that you can't swap the old one out with the new that does support MP3 playback.
Old Apr 21, 2006 | 09:00 PM
TRUGRIDER's Avatar
I've burned some MP3 cd's and mine hasn't been able to read them and mine's an 05 with Bose system?? I've used Nero to burn the cd's am I doing something wrong I mean it does say, "MP3 CD Burn"?
Old Apr 21, 2006 | 09:22 PM
AlcatrazT2's Avatar
You have to burn the MP3's as a data CD, not audio.
Then it should work...to go through folders, if you choose to have them, just press the forward track button for a few seconds and it'll cycle through the various directories.
-George
Old Apr 21, 2006 | 09:26 PM
tiblot's Avatar
just burn them as a regular cd, orgainize them into folders if you want or just leave them all on the root directory
if you are using some obscure brand CD, the cd player may have compatability issues
Old Apr 21, 2006 | 11:41 PM
zackt69's Avatar
rarejdm.com
Mine ocassionally skips... always the same songs though, and only on mp3 cd's. I'm thinking it might be how the songs are compressed? I don't know, anyone have any ideas?
Old Apr 21, 2006 | 11:46 PM
OCGsedan's Avatar
It's likely the disk - as burned disks can easily be worn and cause skipping. (especially if it skips at the same place on the same song..._
Things to try would be to burn a new disk, also, manually set your burning software to a slower multiple x .. which can (depending on device of course) give you a better burn. Finally, sometimes the mp3 file can have a skip in the file itself.. check for that too.
Marlin84
Apr 1, 2020 12:52 PM
Frankieg35
Oct 7, 2015 10:22 AM
SuperSaiyan
Sep 23, 2015 06:13 PM
Phalanx
V36 Audio, Video & Electronics
Aug 10, 2015 11:31 AM
