Right Side Battery Cover Added (Pic)
Old May 5, 2006 | 10:21 PM
  #31
mondo's Avatar
I got mine from Grubbs and it doesn't fit Well, it fits but the ridge for the rubber is too high and the hood doesn't close right.
Update: I searched and found that some take a lot of trimming. That's what I did and now it fits. I'll post some pics of what I trimmed. Basically, the ridge part I thought the rubber gasket went on is really the mark for trimming back to. It fits inside the metal frame... plus I drill one hole (pointing to it) Here's some pics
Attached Thumbnails Right Side Battery Cover Added (Pic)-img_1290.jpg   Right Side Battery Cover Added (Pic)-img_1295.jpg   Right Side Battery Cover Added (Pic)-img_1297.jpg
Old May 6, 2006 | 01:08 PM
  #32
machavez702's Avatar
I got mine yesterday from Grubbs and installed it last night. The instructions suck! There are no pictures of where to locate come of the grounding points, just directions like "the middle of the timing chain cover" or "through the grommet to the battery location". How hard is it to include a couple of pictures with instructions. I got through it but could have save about half an hour if there were better instructions. On a positive note, the wires are high quality and I had no problems with fitment. Install took about an hour.
Old May 6, 2006 | 01:57 PM
  #33
BigSash's Avatar
wtf why do you need wires for a battery cover?
Old May 6, 2006 | 02:32 PM
  #34
yours doesn't have wires?
Old May 6, 2006 | 02:42 PM
  #35
BigSash's Avatar
i dont have a drivers side battery cover, what are the wires for?
Old May 6, 2006 | 02:48 PM
  #36
I'm just messin with ya, the wires are for the grounding kit.
Old May 6, 2006 | 02:51 PM
  #37
BigSash's Avatar
where did any1 say anything about a grounding kit?
Old May 6, 2006 | 04:22 PM
  #38
OCG35's Avatar
Originally Posted by IvoryGT
he means left side...or perhaps "driver-side" would be easier to understand
Probably meant "right side drive"... since it's a JDM part for right side driver cars.
Old Jun 16, 2006 | 03:25 PM
  #39
bythabay's Avatar
I tried doing the same thing and the fit was still tight so i just cut more off.. including the raised ridge (its' gone now)...
Old Jun 16, 2006 | 03:47 PM
  #40
SilverII's Avatar
i got mime over a year ago..... dresses up the engine nicely!
Old Jun 16, 2006 | 05:12 PM
  #41
Msedanman's Avatar
O.F. Administrator
Originally Posted by blancmax
Well, I couldn't stand looking at the hole in the engine bay any longer, so I finally broke down and bought a right side battery cover. Probably not worth the money, but at least I can look at the engine without shaking my head. Now all I need is the Top Secret hood dampeners and some Skyline kickplates and I will officially have the most useless mods of anyone in the group.
A nicely laid out engine bay is very attractive, and the hood lifts are very handy if you're under the hood a lot.
Great mods. enjoy
C.
Old Jun 16, 2006 | 06:29 PM
  #42
ABQ_G35's Avatar
Originally Posted by machavez702
The rod works fine, except you have to use a rod! It's just one of those things that you would expect on a "higher end" vehicle. Hell, they put struts on the trunk lid to eliminate hinges. A rod for the hood can get in the way when you're working under the hood also.
What do you mean "eliminate hinges"? There still has to be a hinge, just not s spring loaded one like old cars had.
jsimonk
Dec 22, 2023 03:49 PM
netcbc
Exterior - Body Parts CDN
Sep 10, 2015 09:20 AM
newg37
Jul 26, 2015 09:32 AM
lemmy999
Jul 25, 2015 12:13 PM
SIKKI
Jul 21, 2015 01:55 PM
