Pulling a trailer?
Old May 13, 2006 | 01:43 AM
BigSash's Avatar
Pulling a trailer?
Anyone ever pull a trailer with their G sedan?
Old May 13, 2006 | 10:36 PM
Andy77's Avatar
There was a thread or two about this and one or two on putting on a hitch. Iwas concerned with one of the hitch threads when someone mentioned since it looked like it attached to a particular piece (??trunk floor??) that if the hitch were hit it would deform the trunk floor and make the total damage a lot worse. This is assuming I remember correctly!
I was thinking about putting on the hitch to carry bicycles simply and safely (it works great on our Subaru), but I have not done it.
Old May 15, 2006 | 09:18 AM
scottcas2004's Avatar
I will be putting one on my sedan soon, the only place that makes on is deLan hitch. Or Curt MFG. That I can find anyways.
Old May 15, 2006 | 10:10 AM
XcarGO's Avatar
I'll probably go for a hitch and utility trailer as soon as I ditch my '96 S-1o Blazer.
As far as a trailer goes I'll look for the lightest possible...All I really need it for is that occasional trip to the Home Depot and need to Carry a 4x8 sheet of plywood.
I think That I read some where that the lights on your trailer had to have there own power source? I guess the wiring harness on the G is too light to carry the extra load...I assume that the trailer will need it's own rechargeable 12 volt battery? Perhaps you could get around this by using LED lights on the trailer?
Old May 15, 2006 | 11:50 AM
You can buy a unit to run the lights that is powered by your car battery.. It's no big deal really, just costs a bit more then tapping directly into the lights.
Old May 15, 2006 | 03:26 PM
myG35ZX's Avatar
I bought a hitch from etrailer.com. I use a small 4x6 "landscaping trailer" to haul my track junk. I lost about 2 mpg with the trailer, but my speeds are over 70mph. The G has enough torque and the wheelbase is sufficient to tow with. I wouldn't tow over 1000 pounds (100 tongue weight). The hitch isn't connected as well as a F350.
Old May 15, 2006 | 04:23 PM
G35_TX's Avatar
I pulled a 1100lb Jetski and Trailer with my 04 G35 6mt. Not a problem doing it. Just make sure you get the separate wiring controller from UHAUL that does not pull power from the brake/lighting system. It needs to pull straight from the battery. It will cause ECU problems if you try it the other way. Mine had issues at first.
Old May 15, 2006 | 05:36 PM
BigSash's Avatar
Can you take a pic of the trailer?
Thanks
Old May 15, 2006 | 11:25 PM
myG35ZX's Avatar
Sure. I'll do it tomorrow.
Old May 16, 2006 | 01:58 PM
CBRworm's Avatar
20 Year Member
I pull a small trailer with a couple of sportbikes on it. I have done a bunch of miles with it so far, but it really makes the back of the car sag. Here is a pic with just one bike on the trailer. Power and braking are fine, I only worry about the load on the unibody. My car is not lowered.
this is the D'lan hitch.
Old May 16, 2006 | 02:35 PM
myG35ZX's Avatar
I would keep the tongue weight under 100 pounds. Your bike is not balanced on the trailer. If you can relocate the wheels forward, it will tow even better.
Old May 18, 2006 | 01:40 PM
myG35ZX's Avatar
My trailer, kind of
My shop is working on the trailer, but here is the drawing. I took a trailer i got form HD for about $400 and am modifying it to carry tires, a 5 foot (130 cubic inch) nitrogen bottle, my ez-up 10X15 canopy and my resin containers (3x3x2). I'll get pics of the finished product as quickly as possible. Everything will be powdercoated for durability.
File Type: pdf
File Type: pdf
Old May 18, 2006 | 01:47 PM
BigSash's Avatar
nice drawing, you make that? what software did you use?
you gonna put the 5ft bottle under the tires?
Old May 18, 2006 | 04:54 PM
boones's Avatar
Here is the Infiniti documentation on how to wire up trailer lights
Trailer light wiring
Old May 18, 2006 | 05:31 PM
myG35ZX's Avatar
Autocad is used by the engineering dpt. Yes, the bottle is under the rack and secured to it. The rack is attached to the trailer after I get everything I need on it and placed to balance the trailer. The tent will lie on the opposite side of the bottom and the tool chest will be upfront (opening towards the tongue. I'm using a box from Lowes - $49.99. A steal and low weight. The only thing I'm looking for is a good tongue wheel and then a rear leg to lower when parked so the trailer will not move/tilt.
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Learned Hand
Oct 1, 2015 09:02 AM
