Main specifications of the VQ35HR and VQ25HR engines:
Smooth transition to top-in-class level engine speed of 7.500 rpm
* Reduction of weight and friction through adoption of asymetrical piston skirt configuration
* Reduction of piston-side force through lengthening of con rod
* Addition of rudder frame, newly-designed cylinder block with significantly improved rigidity
Thrilling revving sound and top-in-class output
* Adoption of perfectly symmetrical intake system
* Adoption of continuously variable valve timing control (CVTC) for intake side and electromagnetic valve timing control (e-VTC) for exhaust side
* Reduction of intake resistance through adoption of symmetrical twin intake system and straight intake port
* Adoption of isometric exhaust manifold and perfectly symmetrical exhaust system
Improvement of fuel-efficiency and emission cleanliness
* Reduction of friction through adoption of world's first hydrogen-free, diamond-like carbon (DLC) coating
* Adoption of catalyst substrate with ultra-low heat mass, super-ignition iridium spark plug and fast light-off O2 sensor control
~Link~
~Link~
So can we please get a G25 like in Japan?
A smaller entry level sedan would be nice too.
Or compact SUV....which makes me wonder if it's going into the compact SUV that's coming out in 2008.Originally Posted by Jspeed
I personally think it would do quite well here in NA.Originally Posted by Jspeed
Quote:
Not sure of the engine but that makes sense. The SUV is supposed to be along the lines or size of the Murano/slightly smaller.Originally Posted by Mr_Ryte
Quote:
I wonder if it will be an Infiniti version of this Nissan concept.Originally Posted by RBull
