2007 G35X - Thoughts
Old Aug 27, 2006 | 08:40 PM
GrowlingG35's Avatar
What is your thought on purchasing a g35x? Does anyone know if the AWD has made improvements? How much heavier is the car going to be?
Old Aug 27, 2006 | 08:55 PM
Garnet Canuck's Avatar
Traveling Administrator
The 07x uses the same ATTESA as the previous gen. The 07 G35x weighs 3703lbs where as the 06 G35x weighs 3668 lbs.
Old Aug 27, 2006 | 09:31 PM
Thanks for replying Canuck. I am forced to trade in my 03 g35 for awd model as I live in Minnesota. Do you know how fast the g35x is?
Old Aug 27, 2006 | 10:32 PM
GEE35FX's Avatar
GrowlingG35..If you get bad weather in the winter, and can use thw AWD then it can't be beat. We love our 05X and our next ride will be another X.
Old Aug 28, 2006 | 02:29 PM
RLampke's Avatar
I have an ’05 X and I'll admit that it's very good in the snow and I’ve had no issues w/the associated hardware - but unless your in the snow often, then I'm not sure that it's worth the weight/MPG penalty [about 300+ Lbs over the RWD] given the days of $3.20/Gal. If your not driving in the snow all that much but at exposed to it as in my case, I'd recommend forgoing the X and instead get the RWD and purchase a great set of performance snow tires. I was amazed on how a performance RWD can behave in the snow w/good snow tires.
Yes there are additional benefits: 25/75 split in high-speed turns and the same upon initial lunch, but again there is the weight penalty, and the X does push more than a non-X.
At least there is a choice.
Old Aug 29, 2006 | 07:59 PM
THanks for the reply RLampke. I love my rwd g35. It snows a ton here but most of the time its plain cold during fall and winter. I only experience the winter 1 time and it was freaking cold and I was told that it was a mild winter. I had a hard time accelerating in my car which was fine with me. I did notice that there were a good number of audi and they did extremely well in the snow. Anyhow my only concern is I like to feel the response and quick acceleration on the g. That is probably the main reason I got the car and the look of course heh. I will most likely test out the new 07 x model or perhaps get a 06 x if the price is ridiculously good. Talk to you later!
Old Aug 30, 2006 | 05:57 PM
Lip's Avatar
Lip
Just to clarify here, the G35x weighs a little less than 200lbs more than an Automatic RWD G35 sedan and about 135lbs more than a 6-speed.
During normal operation, the car is 100% RWD- From a rest, the car has a 25/75 split. Then at about 19mph reverts to RWD unless slip is detected.
The G35x utilizes the FX front end. You'll find that steering effort is slightly higher than in RWD Gs and that there is not as much feel. Fuel mileage is similar. The G35x uses a shorter gear ratio to help optimize acceleration. Thus, freeway engine speeds are unfortunatly a bit higher.
If you live in the snow, the car will perform very well. However, you don't get the 6-speed option. If you don't care about the 6-speed, live in the snow, I think it's really worth considering. I on the other hand want to trade my car for a new 6-speed when available.
Old Aug 30, 2006 | 09:31 PM
Thats right Lip! Thanks for pointing out that 6 speed is not an option. Thats fine with me though. It still does have the tiptronic right? If it doesnt have tiptronic then most likely its snow tires for me and a year later to probably get the 07 sports version. Which would mean I will need to white knuckle while driving in snow. I just love my current G now, but I hate when I see 05 models with the nicer looking rear lights. I usually remind myself that the spoiler is still the look heh. How is the acceleration in highway? Do you feel solid response?
Old Aug 31, 2006 | 07:11 AM
Yep, all X's with the 5AT come with manual mode also.
Old Aug 31, 2006 | 07:17 AM
ma_sha1's Avatar
First get the AWD, then get the super charger,
All worries are gone under All conditions
Old Aug 31, 2006 | 09:54 AM
ForeverYoung's Avatar
Typically...how much slower (0-60mph) are the AWD compared to say the MN6.
gatorglaze
Sep 10, 2015 12:03 PM
kevintandmd
Sep 3, 2015 06:41 PM
pasjr1972
Sep 1, 2015 10:17 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
