Rear side turn signals - LEDs?
Old Oct 25, 2006 | 07:33 AM
Speedoholic's Avatar
G (enie) FUNK ERA
Well? Are they?
Old Oct 25, 2006 | 07:52 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by Speedoholic
Well? Are they?
Doesn't say anything about turn signals.
Originally Posted by Spec Sheet
-LED taillights and Center High Mounted Stoplight (CHMSL), offer quicker illumination, lower power consumption and longer life than conventional bulbs
But if this is the signal... with that shape, you would think LED ?
Old Oct 25, 2006 | 11:58 AM
GoofyG28's Avatar
After I test drove a second time, as I was leaving the dealership, another customer had taken it out for a drive. The dealer was trying to exit the lot and make a left onto a busy street, so it was just sitting there waiting. I got to see the turn signal, and it blinked red inside one of the red rear LED rings. I can't recall if it was LED or not.
If I'm wrong, please correct me.
Old Oct 25, 2006 | 12:05 PM
InTgr8r's Avatar
That makes sense from the spec quote...
The ring is LED for sure.
The center is probably incandescent.
Old Oct 25, 2006 | 12:20 PM
G (enie) FUNK ERA
booooooooooooooooooooooooooooooooooooooooooooo!!!! !!!!!!!
Old Oct 26, 2006 | 03:26 AM
John105's Avatar
Felt that way about the 335, but guess what? I got over it! Plus I liked how the stalk didn't actually remain down or up while turning, it merely acted like a switch, the same as the 745/750.
Have to admit the Passat has some sweet looking tail lamps--all white until the brakes or turn signals go on, then it becomes red/pink.
Old Oct 26, 2006 | 03:27 AM
GoofyG28's Avatar
I went to an early launch event tonight (10/25), and I double-checked the turn signal. It's just a regular incandescent bulb that blinks inside the outer LED taillight rings.
Old Oct 26, 2006 | 09:45 AM
chilibowl's Avatar
Why do they cheap out on the G's. The FX has nice sick LED's for both braking and signaling....the coupe better have full LED's for everything, or im going to b maddddd
Old Oct 26, 2006 | 04:19 PM
dampfnudel's Avatar
I thought the new G used the outer LED's for signaling, based on the FX. Speaking of the Passat's taillights, the '07 TL base model has something similar (not round, but white sections which light up red with the LED's more visible than before). The TL still uses a regular incandescent bulb for signaling.
Old Oct 26, 2006 | 08:41 PM
John105's Avatar
The coolest and the best are still the first--Cadillac. I think the reason is they are tiny dots, and they are not in a straight line. Somebody came up with this design and knew what they were doing. I have a friend who has a STS, and when I told her about her LED tails she had no clue what I meant. I had to ask her b/f to step on the brakes and hit the turn signal and have her come to the rear of the vehicle--she said she had no idea it looked like that and it WAS cool....
Muski_G
Dec 1, 2023 11:11 AM
rezendvous420
May 31, 2020 01:26 PM
yoyoyo8
Aug 12, 2015 03:04 AM
MT6002
Lighting
Jul 21, 2015 01:13 PM
