Heated Seats?
Old 11-21-2006 | 05:14 PM
Railgunner's Avatar
Heated Seats?
It's 36 degrees out and raining and I decided to try out my heated seats the 1st time today on the way home from work.
I flipped it to "high" and waited... and waited... and waited... Finally after about 5 minutes I felt a little warmth in the seat back but nothing in the seat cushion.
Hmmm... I turned on the heater for the passenger seat and left it on for about 5 minutes and felt it.
The back of the chair got warm but not the seat cushion.
So it seems that the only part of the seat that is heated is the seat back
and not the cushion?
Can someone else confirm?
Old 11-21-2006 | 05:18 PM
GoofyG28's Avatar
That's weird. I didn't even know the back of the seat heats up. When I put it on low, I definitely feel the warmth from the seat bottom. On high, it sometimes burns my a$$. Can't wait to really use them when the weather gets colder here. Thanks to global warming, it's still in the mid 60s here in the Bay Area.
Old 11-21-2006 | 05:38 PM
Sedanman07's Avatar
Waxer
My seat bottom gets warm but it does take awhile.
Old 11-21-2006 | 06:22 PM
RINO's Avatar
my a$$ is hot all the time
Old 11-21-2006 | 06:39 PM
DenverG35X's Avatar
Both the lower back and the seat cushion should get warm/hot. It does take a while though.
Old 11-21-2006 | 06:43 PM
HuKaShI's Avatar
Yeah, I got a pretty hot a$$ as well.
Old 11-21-2006 | 06:45 PM
omgitselaine's Avatar
hmmm ...heated seats ... is the one option i definatly want to get
Old 11-21-2006 | 06:48 PM
GoofyG28's Avatar
Because your a$$ is not hot enough yet?
Old 11-21-2006 | 07:20 PM
95se's Avatar
My a$$ is hot, but not as hot as it used to be.
Old 11-21-2006 | 07:26 PM
allforthecash's Avatar
the heated seats in our G's sucks.....period........
Old 11-21-2006 | 08:48 PM
wavelengths's Avatar
With heated seats, the Germans will always own the Japanese, badly.
A pair of MB seat heaters will literally light a fire under your...well, let's just say using second-stage heat requires heck to freeze over. With the G35 the second-stage heaters help a little bit, but they're largely just to take the edge off.
Old 11-21-2006 | 11:14 PM
Q56_Monster's Avatar
Heated, and for that matter, cooled seats in the M are weak too. I betcha the M & G now have common parts.
Old 11-22-2006 | 01:26 AM
RockyR's Avatar
I posted about this very same thing a few weeks ago. heat seemed weak. But you know, now I've gotten used to it. Maybe it got hotter? I don't know.
At first I thought the lower setting was worthless. But now, I like the subtle heat it gives. It's like the High setting on the new car is equal to the Low setting on my old 2003. And now we have a weaker yet 3rd setting.
Old 11-22-2006 | 11:22 AM
GoofyG28's Avatar
How come no one has invented heated steering wheel and heated shift ****? Because my 6MT's shift **** vibrates like crazy, even at idle, it would be a big seller to females if it also warmed up, too.
Old 11-22-2006 | 11:27 AM
Garnet Canuck's Avatar
Traveling Administrator
The 07 Maxi can come equipped with a heated steering wheel and even heated rear seats! Heated rear seats would come in handy in the winter if you wanted to go "parking" with your woman!
Quick Reply: Heated Seats?
