Problem with HDD Navigation and Music Box
Old Nov 27, 2006 | 04:07 PM
Christian's Avatar
Has anyone else had trouble with the harddrive in very cold weather? It has been -20 degrees celcius here for the the past couple of days , and when I first start my car the navigation and music box will not work. After the car warms up if I "reboot" the car the hard drive works. Do you think there is something wrong with my HDD? Should I take it into the dealer?
Old Nov 27, 2006 | 04:22 PM
Speedoholic's Avatar
G (enie) FUNK ERA
That's my only concern with all the technology that has been shoved into this car: More things to go wrong.
As for your question: I wouldn't be surprised. My Bose headunit kept on skipping CDs in cold weather.
Old Nov 27, 2006 | 04:26 PM
Garnet Canuck's Avatar
Traveling Administrator
Interesting Christian. I could be wrong, but I believe that most HD's have a storage temperature rating down to -40 degrees. So you should be ok I think in that regard. Hopefully the power supply that runs the HD is rated for the same cold temps. One potential problem that I see is that the newer hard drives use liquid bearings, kind of like motor oil in a car. We all know that oil gels in really cold temps so this could be causing your HD to to not boot until it warms up a little. Just a thought.
Old Nov 27, 2006 | 05:36 PM
Christian, how long does it take before the HD boots up after your car is started?
Old Nov 27, 2006 | 05:39 PM
Christian's Avatar
Once I've let my car warm up for a few minutes I have to turn the car off and back on to get the drive to boot so that I can access the map or the music box.
Old Nov 27, 2006 | 06:02 PM
I would bet anything that it is the oil-based liquid bearings in the HD that is causing that.
Old Nov 27, 2006 | 06:10 PM
G35string's Avatar
If I was in -20 degree C weather I think I'd need a reboot like the G's harddrive!
Old Nov 27, 2006 | 06:19 PM
Sedanman07's Avatar
Waxer
Disk drives have an Operating range: 2° C to 35° C (41° F to 95° F)
A Nonoperating range:-40° C to 68° C (-40° F to 158° F)
So it doesn't surprise me it doesn't work well at -20.
(yes I work for a computer company)
EnCr1pt3d
Jul 8, 2019 02:48 PM
willdogs
Dec 8, 2015 11:32 AM
Daniel k.
Nov 3, 2015 09:52 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
mcneil_g35
Aug 5, 2015 12:03 PM
