Heated Seats??? Not really...
Old Dec 5, 2006 | 07:05 PM
  #31
N50's Avatar
N50
Originally Posted by johnmax
They suck in the FX too. I was hoping that they fixed that. I guess not.
I definitely feel that the heated seats in an '03 fully loaded loaner I was given awhile ago heated faster and hotter than the ones in my '04 FX.
Old Dec 15, 2006 | 01:01 PM
  #32
z28lt1's Avatar
I was hoping to use the poll, but I think a lot of non 2007 owners voted. So I'm going to bring this thread with my new data to the dealer, this afternoon.
Today, I did a comparision of the seat heaters in my Tahoe vs my 2007 G35x. I used my infrared heat sensor, in close enough range to determine the heat of the seat in about a 1/4-1/2 inch spot of the seat. I turned on the seat heaters in both cars, and took measurements in about 8 spots on each seat versus a specific time, and looked for the hotest spot. To spare everyone from the gory deatails and measurements, here is the summary.
Outside temperature in the low 50's (F). And starting seat temperatures were 55-62 in the Tahoe and 51-60 in the G. (It's amazing the temp change on the different spots of the seats, the side of the seat getting the sun was up to 9 degrees warmer than the other side of the seat). The Tahoe was on the sunny side of the driveway.
In the Tahoe after 6 minutes, the spots where the seat heaters seemed to run averaged in the low-mid 90s (F), with the hotest spot at 101.
In the G35, after 6 minutes, the average temp was in the low 60s with the hotest spot at 70. After 15 minutes in the G35, the hotest spot was 78, with the averages around 69.
EvenfForgetting the comparison to the Tahoe, it seems that my seat heaters are just about worthless.
I'll let everyone know what the dealer says.
Old Dec 15, 2006 | 01:12 PM
  #33
Garnet Canuck's Avatar
Traveling Administrator
Very interesting tests, great stuff. Let us know how you make out at the dealership.
Old Dec 15, 2006 | 01:55 PM
  #34
RBull's Avatar
Rated M
Great job with the test. Nothing like having your ducks in a row.
Good luck.
Old Dec 15, 2006 | 04:38 PM
  #35
wavelengths's Avatar
Spec on the Infiniti seat heaters at their top setting should be 80F. So yes, they're weaker than weak, but they do work if they're set properly and left on to heat up for a bit.
Old Dec 15, 2006 | 10:17 PM
  #36
CorumG35's Avatar
The seat heaters in my Audi TT can fry an egg. They get SUPER hot if you crank them all the way up. That may have skewed my frame of reference but my G35 seat heaters are barely noticable.
Does anyone know if there is a sensor determining if a seat is occupied, and turning off the heater accordingly?
Old Dec 21, 2006 | 09:05 AM
  #37
dcmidnight's Avatar
I'm driving an 06 g35x loaner right now and the seat heaters are great, almost as piping hot as the ones on my Z. Wifes 06 FX35 are unreal, in fact you can never use the high setting, they get that hot.
Will report back on the 07 ones
Old Dec 21, 2006 | 10:28 AM
  #38
RBull's Avatar
Rated M
Originally Posted by GEE35X
I guess I already got enough extra padding there to keep me warm .
LOL, I've got a little more on me lately since I haven't been running.
Old Dec 21, 2006 | 10:29 AM
  #39
RBull's Avatar
Rated M
Yes, all cars have thermostats controlling the seat heaters allowing them to reach temp and cycle on/off as necessary.
Old Dec 21, 2006 | 10:40 AM
  #40
moose1963's Avatar
This is the first car I've had with heated seats. I rarely use the high setting. Low works very well in my car.
Old Dec 21, 2006 | 12:05 PM
  #41
Seahawk's Avatar
07 G35x here that the seat warmers suck as well, tho the passenger seat gets much warmer and more quickly than the driver seat...???
Old Dec 21, 2006 | 01:33 PM
  #42
gao's Avatar
gao
I thought my G35x was the only one with the wierd heating imbalance.
Old Dec 21, 2006 | 01:48 PM
  #43
mikepro's Avatar
Do you know where these are located? Somewhere under the seat I'm guessing???
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
DRG35R
Jan 31, 2016 07:14 AM
hrdwirk1
Oct 2, 2015 06:34 PM
doakley92
Sep 25, 2015 12:58 PM
