New Car Tire Pressure
Old Feb 6, 2007 | 10:21 PM
herschelg123's Avatar
Originally Posted by kring
slightly off subject, but in the same theme of tire pressure. My dealer says they fill the tire with pure nitrogen, does that effect tire pressure recommendations?
That is funny. When I let the air out of the tire, it smelled completely different than any other tires I have deflated. I bet it was nitrogen.
I have been told by salesmen at American Discount Tire that the nitrogen slows down the escaping air so the tires maintain their correct pressure over a longer peroid of time. Also, the nitrogen maintains its temperature, so the tires keep a more consistant PSI when they get warm. The people at American Discount Tire also said that they would NOT fill it completely with nitrogen. They use a ratio of something like 20% nitrogen and 80% air.
Anyway, that is what I was told.
Old Feb 7, 2007 | 12:39 AM
Derp's Avatar
Regular air is already 78% Nitrogen.
The only reason that race-teams use pure nitrogen in tires is that they can accurately calculate the pressure changes as the tires heat up. A pure gas obeys the pressure/tempurate gas laws more exactly than a varied mix of Nitrogen, Oxygen, CO2, and water vapor. The variable humidity in "regular air" is probably the biggest problem since the vapor can condense inside the tire and really throw the pressure curves.
Old Feb 7, 2007 | 10:01 AM
c2t'sG35x's Avatar
Originally Posted by randman
Strange. You may want to call the dealer (or double check that your tire gauge is accurate - I don't know what kind you have, but many of the pen-like tire gauges are very inaccurate).
Its actually a pretty accurate needle gauge because I hate those pen type gauges! I don't even know why or how they manage to sell those anymore. I'll give the warning a few more days as it may need time to adjust to the change in tire pressure. If that doesn't work I'll pull the fuse and see if that forces it to reset.
Old Mar 27, 2007 | 01:20 AM
kiwijunglist's Avatar
my car just came shipping from japan, all the tyres were 25psi which seemed crazy. Just pumped then up to 37psi
Old Mar 27, 2007 | 02:16 AM
caveman666's Avatar
Originally Posted by c2t'sG35x
Mine were at 42psi so last night I brought them all down to 36psi and now my dash has the low tire pressure warning lit. What do I need to do to get the light to go off?
Put more air in
Old Mar 27, 2007 | 08:32 AM
SPEEED's Avatar
Bad Toro
Didn't check mine when I picked it up, but it has nitrogen. I got this card to register the car online. I'll post a new thread about this as I'm not familiar with this process and I also don't want to hijack this thread.
Old Mar 28, 2007 | 11:31 AM
Canadian Driver's Avatar
I picked up my vehicle on Friday from the dealership. The other day it was quite warm in Toronto and I was driving around and noticed the ride was a bit too stiff especially over rough roads and tracks. I checked the tire pressure and low and behold it was around 48+ psi. Well it seems that when the dealer prepped the vehicle they forgot to check and change the tire pressure. I adjusted it down to 33psi as recommended. Today I noticed the TPMS warning light on the dash is lit. Does anyone know how to reset this without having to go back to the dealership?
Old Mar 28, 2007 | 12:15 PM
Tiger's Avatar
Did you deflate the tires when they were hot? If so, the cold tire pressure is now in the 20's. That is what is causing the light to turn on.
Old Mar 29, 2007 | 01:19 AM
jzoloto's Avatar
I found the same thing as most of you did that the tires from the dealer were over-inflated. Mine were about 38-42 psi. I toned them down to around 33 each. That was a great call. Thanks for bringing it up.
Old Mar 30, 2007 | 03:25 PM
nishlaaa's Avatar
Difference in fuel economy?
Has anyone compared the MPG before and after adjusting the over inflated tires?
I just bought my car two days ago and haven't had a chance to measure the tire pressure yet to see if mine were overinflated, but I'd be curious to see what kind of improvements are made in the fuel economy.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
ghost_g35
Aug 7, 2015 10:31 AM
itschuckster
Jul 25, 2015 08:07 AM
