Speaker Adaptation - Does it Actually Work?
Old Feb 21, 2007 | 12:43 AM
gstais's Avatar
Question Speaker Adaptation - Does it Actually Work?
Have any of you tried the Speaker Adaptation Training described on Pages 4-77 through 4-79 of the User Manual? This is supposed to be another learning function for Voice Recognition, but I am unable (after several attempts) to get it to work.
The manual states that in order to activate this process, you need to have the car running, in Park, with the Emergency Brake engaged. Once you do this you are supposed to hold down the "Phone/Send" button for more than 5 seconds. After the 5-second wait, the system is supposed to be activated, and proceed to prompt you to repeat a series of commands that are supposed to create a "voice profile". The objective here is to make voice recognition more efficient, and accurate.
Well, guess what, I have tried this several times, and the system does not even activated after 5+ seconds.
Is this a problem or another feature that Infiniti decided to leave out at the last minute?
Thanks.
Old Feb 21, 2007 | 12:52 AM
terrycs's Avatar
Thanks.
Does the default system have problems understanding you? I believe this process is helpful if you speak with an accent and the system misses what you say a lot, otherwise you might be wasting your time. I did it to fool around with it while waiting for the wife with the car off and it worked.
Old Feb 21, 2007 | 11:32 PM
gstais's Avatar
Yes, sometimes the system misinterprets my voice commands. And no, I don't speak with an accent.
My issue is I can't even get the option to work. When I hold down the Phone/Send button for more than 5 seconds, nothing happens (Which side of the button are you supposed to depress, anyway?)
Old Feb 22, 2007 | 10:54 AM
wavelengths's Avatar
You can also get into training via the settings menu I believe. I did it the first night I had the car - voice training helps any voice recognition system.
As for hints to help it work a little bit better - hitting the Enter button (on the steering wheel) after issuing a voice command will tell the system to stop capture and start figuring out what you just said. I have found this increases accuracy as it will be less likely to think that cabin noise or other people asking questions are a command.
Old Feb 22, 2007 | 12:10 PM
NewMexicoG's Avatar
I couldn't enter phone numbers right until I did this. It would always give me zero instead of four. I followed the instructions as they are in the manual and everything worked just fine. I don't have a funny accent either, it was just a problem with four. Now the system works everytime. If you read the manual it tells you exactly which buttons to press (the phone button is actually two).
Old Feb 24, 2007 | 11:08 AM
G35Now!'s Avatar
Moderation-free
+1
After reading this thread, tried it - worked great, too soon to know what the improvement is.
EnCr1pt3d
Jul 8, 2019 02:48 PM
Gip
Aug 24, 2015 05:31 PM
DRG35R
Jul 31, 2015 10:23 AM
joedaddy1
Jul 28, 2015 02:58 PM
beevanhuynh
Jul 14, 2015 09:06 AM
