Pics Of Stillen Exhaust Underbody
Old Feb 21, 2007 | 02:08 PM
acidrane's Avatar
i havent seen the stock exhaust system on the new g yet, but im sure its not EXACTLY the same. has anyone done a custom exhaust? complete with x-pipe insted of y?
Old Feb 21, 2007 | 02:40 PM
moose1963's Avatar
A few things I did notice when comparing sedanman07's pic (https://g35driver.com/forums/showthr...hlight=exhaust) with the Stillen pic was the cats are different (possibly higher performance) and the pipes exiting the cats seemed much larger. (Also the pipes entering the cats seemed larger as well but not really sure.)
Could these differences account for a moderate boost in HP and TQ (generally in the 10-20 HP range for this type of mod)?
Old Feb 21, 2007 | 03:02 PM
kring's Avatar
I'll clarify/defend my point of "exactly" the same, I said it looks the "same", I didn't use the word "exactly" and by the "same", I was implying it's design a 2-1-2 system and not a true duel exhaust. and by the "same" I was also implying my guestimates of performance.
Old Feb 21, 2007 | 03:08 PM
acidrane's Avatar
say that again one more time....hehe. understandable. maybe the stock system is soo well built that all they needed to do is use bigger pipes, better flowing cats and make it light weight. tho common sense would say that the x-pipe SHOULD produce more power/tq. i need to go talk to my exhaust guy to see get his opinion.
Old Feb 21, 2007 | 03:13 PM
moose1963's Avatar
I meant no offense. I wasn't trying to make you clarify or defend anything. I just happened to remember seeing a picture of a stock underbody, put the pictures side-by-side and made a few observations. I was just wondering if the things I noticed would make a moderate performance improvement. That's all.
Old Feb 21, 2007 | 03:17 PM
trey.hutcheson's Avatar
I think you're confusing the cats with inline resonators.
Old Feb 21, 2007 | 03:35 PM
moose1963's Avatar
I just did some quick research and let me see if I have this right. Out of the exhaust manifold you have the headers going into a pre-cat. Then a down pipe into the cat. Then comes the y-pipe. The the inline resonators, then the mufflers. Close?
Old Feb 21, 2007 | 03:38 PM
UltimateGee27's Avatar
NO FIRST YOU HAVE THE HEADERS THEN YOU HAVE THE EXHAUST MANIFOLD A NINER THAT GOES INTO A 364 TYPE A SPEC DOWNPIPE WHICH THEN CONVERTS TO AN EAGLE 1 DELTA WHICH IN TURN YES IS A DOWNPIPE..AFTER THAT IT GOES INTO A NON FRICTION ZONE RESONATING TYPE PIPE MANIFOLD WHICH IS CONNECTED TO THE Y PIPE WHICH IS ALSO CONNECTED TO THE FUNNY BONE ERRRRRR WAIT I MEAN CATALYTIC CONVERTER AND THEN EXITS THRU THE MUFFLER.... I THINK THATS RIGHT...
Old Feb 21, 2007 | 03:42 PM
SPEEED's Avatar
Bad Toro
I think exhaust by itself as a mod to add more power is overrated, much like an intake. The amount of power you get in compared to $$$ amount spend is irrelevant.
Old Feb 21, 2007 | 03:45 PM
BUT....... the amount you gain when you wake up in the morning and fire that b***h up and stand back and listen to that SWEEEEEET exhaust note is *PRICELESS*
LIKE MY MAN QUAGMIRE WOULD SAY... ALLLLLLLL RIGHT
Old Feb 21, 2007 | 04:35 PM
You've got the exhaust manifolds that connect to the cats. The cats then connect to the y/x pipe. From there you have the two output pipes with inline resonators that route to the mufflers.
The previous generation sedan was a little different. Exhaust manifolds > cats > ypipe > midpipe(single, with resonator) > rear section(muffler).
Old Feb 21, 2007 | 05:59 PM
SPEEED's Avatar
Bad Toro
Indeed!
Old Feb 21, 2007 | 06:48 PM
CFar's Avatar
Not bad
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
Spartan268
Aug 20, 2015 09:14 PM
linedr89
Aug 17, 2015 05:11 PM
Team STILLEN
Aug 10, 2015 08:17 PM
