Yet ANOTHER annoying radio behavior - preset buttons / manual tuning
Old Feb 22, 2007 | 09:40 AM
dcmidnight's Avatar
Add this to the list of quirky bugs in the audio system that is slowly driving me crazy. Unfortunately this list is adding up. If this radio were a piece of software being released I think it would be a Beta Version 0.8 rather than a release Version 1.0.
Lets say on Preset A I have 6 preset channels.
30
40
50
60
I go to Preset 3 - Channel 30 - and manually tune down to Channel 32. I'm listening for a while and decide I want to go to another preset.
Now if I bump the steering wheel control up or down arrows, I would think it *should* take me to either 1 - the preset on either side of 32 or 2 - the preset on either side of 30 which is the last preset I went to. Either of these I could live with.
Instead, up takes you to Preset 6 and down to Preset 1. Argh! As if manually tuning the radio is just to confusing for the computer and it "starts over" in the ether above Preset one and below Preset 6.
Old Feb 22, 2007 | 02:14 PM
GoofyG28's Avatar
The steering wheel up-down button always takes you to the 1 thru 6 presets.
Old Feb 22, 2007 | 02:18 PM
G-Whizzer's Avatar
I think he's saying that one would expect it to take you to the next closest preset... - so if you manually tune up from preset #2, then the wheel button would take you to preset #3 - or #1.
Maybe it's looking at the actual station number?
Or are these XM radio channels?
Old Feb 22, 2007 | 02:19 PM
dcmidnight's Avatar
Yes these are XM stations.
I know what the button should do - I just wish it should do it differently.
If I use the Up/Down between presets to go to Preset 3 and then manually tune to Channel 32 - the presets on either side are 30 (Preset 3) and 40 (Preset 4) - the up/down would hopefully take you to the closest preset. But no matter what manually tuned station you are on on whatever part of the dial - Up takes you to Preset 6 and Down takes you to Preset 1. Personal preference I guess.
Old Feb 22, 2007 | 02:24 PM
G-Whizzer's Avatar
That IS odd... I don't think it behaves that way on our M45.
I'll test it later.
Old Feb 22, 2007 | 03:03 PM
terrycs's Avatar
I used to think it was a PITA too, but learned to set the XM presets by genre instead of specific stations, then tune manually within the genre. I think it actally makes sense given the number of stations you would be incrementing on the steering wheel.
Old Feb 22, 2007 | 03:08 PM
dcmidnight's Avatar
I actually have mine segmented by genre over the Preset "Letters" - A (music) B (sports) and C (talk).
Old Feb 22, 2007 | 03:12 PM
Christian's Avatar
Are you using the steering wheel button to manually scan or the **** on the console?
Old Feb 22, 2007 | 03:14 PM
dcmidnight's Avatar
Steering wheel to cycle through presets - **** on console to manually tune from there. I just don't see why the radio isn't "smart" enough to say "OK I'm on Preset 3 at Channel 30. I was manually tuned to Channel 32. The "up preset" button on the steering wheel was hit. What do I do?"
My argument, and I would argue logic, is it should go to the nearest preset - back to Preset 3 / Channel 30 in my example. In reality, the radio will actually bump you completely out of that loop and take you all the way to Preset 6. As if manually tuning somehow wipes out any memory it has of where it is on your dial. This makes no sense to me.
Like I said, maybe there's a good reason they did it, it just seems illogical to me.
Old Feb 22, 2007 | 03:19 PM
Christian's Avatar
Steering wheel to cycle through presets - **** on console to manually tune from there. I just dont see why the radio isnt "smart" enough to say "OK I'm on Preset 3 at Channel 30. I was manually tuned to Channel 32. The "up/down preset" button on the steering wheel was hit. What do I do?"
My argument, and I would argue logic, is it should go to the nearest preset. If its manually tuned to 12 (between Presets 1 and 2) and you hit "up preset" it should go to the nearest preset which is in the case Preset 1 / Channel 10. But in reality it takes you from between Presets 1 and 2 to Preset 6. The radio will actually bump you completely out of that loop.
Just hold the steering wheel button up or down to manually scan back to the preset chanel, that should work I think.
Old Feb 22, 2007 | 04:42 PM
g35_neat_car's Avatar
My 05 coupe has the same quirk. Doesn't appear they changed this. After a couple of years it still catches me off guard.
Old Feb 22, 2007 | 04:45 PM
dcmidnight's Avatar
Looks like (for XM at least) this takes you to the start of the next genre of music actually, not preset.
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
AuAltima3.5
Audio/Video/Electronics
Sep 12, 2015 08:21 AM
zcherub
Sep 10, 2015 12:03 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
