Adaptive Headlights turning question
Old Feb 22, 2007 | 05:22 PM
pangpang77's Avatar
Something interesting I noticed. In the garage in "Park", when I turn the steering wheel, only the right headlight moves back and forth with the steering wheel, but not the left headlamp. But I did notice that the left headlight moves on real world turns. Anyone shed some light on how it's supposed to work. At first I thought the left side was not working, until I monitored it on a left turn.
Old Feb 22, 2007 | 05:29 PM
Christian's Avatar
Explanation from the manual:
Originally Posted by OWNER'S MANUAL
The AFS will operate:
  • when the headlight switch is ON.
  • when the selector lever is in any position
    other than P (Park) or R (Reverse).
  • when the vehicle is driven at above 16
    MPH (25 km/h) for the left-side headlight.
    Note that the right-side low
    beam headlight will swivel but the left
    side will not swivel when the vehicle
    is at a stop and the steering wheel is
    turned. The vehicle must attain a
    speed above 16 MPH (25 km/h) before
    AFS activates the left-side headlight.
Old Feb 22, 2007 | 06:39 PM
kewltea's Avatar
How hard do you think it would be to add AFS?
Old Feb 22, 2007 | 07:14 PM
coupin827's Avatar
Good find.
Old Feb 22, 2007 | 07:42 PM
hokiesean24's Avatar
nicely said Christiann.
Old Feb 22, 2007 | 07:45 PM
terrycs's Avatar
I bet one of the things missing on the non tech version is the steering position sensor which is used for the headlights and back up camera.
Old Feb 22, 2007 | 07:52 PM
kewltea's Avatar
A bit off topic, but how good is the backup camera for depth perception?
Old Feb 22, 2007 | 07:54 PM
max2k1's Avatar
I think like most high tech items in complex cars (like this one), it would be very expensive to retrofit it after the fact.
(i.e. if you can even find the parts/expertise to do the job)
terrycs's Avatar
VERY good. I park about an inch from the cabinet in my garage every time. The bumper is clearly visible in the camera.
Old Feb 22, 2007 | 07:56 PM
terrycs's Avatar
Agree ... moving headlight assy, backup camera controller, and backup camera/spoiler need to be added. This is assuming the wiring harness is the same.
randman's Avatar
The backup camera has lines superimposed on the video which give you an idea of how far away the rear of the car is from objects behind you. I got the tech package for the intelligent cruise control, and I didn't think I'd care much for the camera. However, I've gotten spoiled by the backup camera and I find it very useful. It has a very wide angle lens. I find it useful when backing out of a parking space and there are big SUVs to my left and right, since I can see more out back than what the rear view window shows. I also find it useful when backing into a parking space, and there are no cars to my left and right, since I can see the lines in the parking space while backing up.
Old Feb 22, 2007 | 08:04 PM
kewltea's Avatar
That is the main reason why I would of liked the camera. Tired of opening the door and sticking my head out as I reverse in
Old Feb 22, 2007 | 08:05 PM
terrycs's Avatar
No more tennis ***** hanging from the rafters!
Old Feb 22, 2007 | 09:20 PM
dude_abides's Avatar
It also sees pretty well at night. The backup and tail lights help, but it's also quite sensitive in the dark.
Old Apr 3, 2007 | 01:13 PM
rob40wilson03's Avatar
the thing i wish my 06 coupe had the most is the adaptive lighting..... i would love to think that it would be possible and not extremely expensive to add, but i will certainly not get my hopes up
