Music Box Discovery .
Old Mar 2, 2007 | 09:33 PM
terrycs's Avatar
OK, some of you might know this, but I didn't sure didn't ...
I always hated navigating the MB to find a particular album because you can't do it on the move.
Solution:
Set the MB to search by artist. Then tune to the artist you are looking for on the right hand station selector dial in front next to the CD slot. It can scan through your entire library in alpha order VERY fast AND you can do it on the move. Of course, you can also scan by album title in alpha order.
I hope this helps someone.
Old Mar 3, 2007 | 02:09 PM
chrisbel's Avatar
Solution:
Although you can't search while moving, you can change what the right hand dial scrolls through while moving by selecting 'menu' on the screen then 'play by [artist, album, mood, etc]'
Old Mar 3, 2007 | 02:13 PM
terrycs's Avatar
Exactly, and I can get to the desired album MUCH faster than using using menu picks (when the menu is unlocked).
Old Mar 3, 2007 | 02:14 PM
G-Whizzer's Avatar
So whatever you leave it on in the menu setting, it uses that for the ****?
Cool tip! Thanks.
Old Mar 3, 2007 | 02:17 PM
terrycs's Avatar
Cool tip! Thanks.
Yes ... try it out. I have about 30 disks on there and I can get to the desired album in about 5 - 10 seconds ... while car is moving.
Picture Share
Feb 4, 2018 12:41 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
prinny
Nov 22, 2015 11:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
