Music box delete/undelete songs
Old Apr 12, 2007 | 12:50 PM
Altersys's Avatar
Is there a way to force delete a song or album such that the music box does not "undelete" the tracks when you reinsert the CD? I want to permanently delete and then re-record the tracks, but when I try this the HDD simply undeletes the same tracks rather than recording a new set.
thanks
Old Apr 12, 2007 | 03:05 PM
mobileg35's Avatar
exact same problem
the original CD had some marks on it that caused the copy in the music box to have "noise".
so I delete this version in music box.
when I put in the cleaned up CD, the music box brings back to life the older "noisy" version.
very irritating!
Old Apr 12, 2007 | 04:14 PM
Altersys's Avatar
yep. that's one of the scenarios I'm dealing with. The HDD should have a "delete permanently" feature....
Old Apr 12, 2007 | 04:23 PM
timn99's Avatar
Noticed this a well. Only way to do it was to DELETE ALL the entire Music Box. Major downside is you have to record all albums again.
Old Apr 12, 2007 | 04:25 PM
Altersys's Avatar
frack. i had a feeling that would be the answer. Infiniti should address this in their next navi update!!
Old Apr 12, 2007 | 04:28 PM
kring's Avatar
That's not correct, the Delete ALL doesn't actually delete all, it only deletes all the music you had marked for deletion! in order to delete the entire music box, you need to mark all the music for deletion, then do a delete all.
I put in the Dave Mathews CD which has 20 blank 3 seconds tracks, I went and deleted all those tracks, I then hit the delete all and it only got rid of the 20 empty tracks.
Old Apr 12, 2007 | 05:47 PM
Altersys's Avatar
seriously?! Right fricken on! That will work! Thanks kring!
Picture Share
Feb 4, 2018 12:41 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
prinny
Nov 22, 2015 11:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
