SAT Radio Reception Issues
Old Apr 12, 2007 | 11:16 PM
coupin827's Avatar
Hey, wanted to find out if anyone else is having reception issues with their 07?
I have XM since I have the NAV package. Lately the reception has been ****ty in the NYC/Central Jersey area for me. It keeps cutting in and out all the time and it's getting frickin' annoying as hell.
Wanted to see if anyone else has had such an issue.
Thanks.
Old Apr 13, 2007 | 09:01 AM
GumboChief's Avatar
Only times I have gotten drops is when I spend more than 5-7 seconds under an overpass.
Old Apr 13, 2007 | 09:17 AM
sjharris's Avatar
Thanks.
I have had the same up here in CT (and when I drive to NYC)
Old Apr 13, 2007 | 09:36 AM
GumboChief's Avatar
Does it work when parked in your garage?
Old Apr 13, 2007 | 10:03 AM
sjharris's Avatar
I don't park it in the garage.
Old Apr 13, 2007 | 10:52 AM
Christian's Avatar
I haven't had any problems except under overpasses and behind one particular mountain when I go snowboarding. It even works in my underground parking spot at work.
Old Apr 13, 2007 | 11:09 AM
max2k1's Avatar
Mine has no reception problems (but we don't have tall buildings around here !!!)...
It however has trouble working in my garage -- not all channels work inside the garage --- some do and some don't !
Old Apr 13, 2007 | 12:12 PM
Adam Zapple's Avatar
XM uses both satellites and terrestrial for delivery. The terrestrial is normally only in large cities where line of site of the satellite is not guaranteed. You will notice as you travel through tunnels in a city that most of the time you will not lose your signal.
I live just outside of Seattle. This is tree country and trips over to Redmond resulted in signal loss. In the city it is fine because of the terrestrial transmitter.
I suspect that your area is not covered by both the terrestrial and satellite. Ironic when XM claims it has better terrestrial coverage, but Sirrius has a better orbit for it's satellites. So pick your evil.
I have had both here in the NW and neither are perfect with guaranteed signal loss when going down a road with trees on each side. The reason why I did not renew my subscription is because of this issue. We're not talking country roads either. I'm talking Redmond Way off I405.
Old Apr 13, 2007 | 01:23 PM
DaCurryman's Avatar
5-7 seconds? My signal cuts out momentarily many times as I'm just driving under a regular overpass at like 65mph, where I'm only under for a second or less.
Old Apr 13, 2007 | 01:24 PM
DaCurryman's Avatar
Apparantly NYC hasnt picked up this feature yet. I get reminded that I'm listening to satellite every morning when I drive into the Midtown Tunnel and the music goes bye bye...so for the 5 mins I spend in the tunnel, I listen to good old FM.
Old Apr 13, 2007 | 01:29 PM
sjharris's Avatar
I would think that NYC has repeaters. I know they have a lot there for Sirius.
Old Apr 13, 2007 | 02:08 PM
SPEEED's Avatar
Bad Toro
Haven't really listened to XM lately (not since I got a car with a CF slot in it ) but from the few times I DID listen to XM, I didn't notice any problems. I'd have the antenna checked by the dealer.
Old Apr 13, 2007 | 02:35 PM
Garnet Canuck's Avatar
Traveling Administrator
There is a certain street in my city that the reception will cut out. There is nothing overhead except a bunch of power lines.
Other than that specific street, it works great.
Old Apr 13, 2007 | 06:30 PM
g u l8er's Avatar
same here with the no signal in the garage. as soona s i pull in there will just be a hissing noise.
Old Apr 14, 2007 | 01:12 AM
coupin827's Avatar
Thanks for the info guys. I think I'll have it checked out because it is super annoying.
WillisFL
Dec 29, 2016 08:56 AM
Frostbite91
Aug 20, 2015 07:20 PM
Phalanx
V36 Audio, Video & Electronics
Aug 10, 2015 11:31 AM
kd03g99
Jul 30, 2015 11:24 AM
