Edmunds.com Knock the 6MT's Clutch - What's Your Take?
Originally Posted by muscarel
I never minded the clutch in my '04. The only thing that was annoying was the coarsness as you shifted from 1-2 sometimes.
Has that gone away in the 07 sedan? What about the tiny vibrations?
So it needs a bit of practice to nail the 1-2
What "tiny" vibrations ??? .... the shifter still vibrates a lot .....
None of these even compare to the clutch weight of my old Turbo NX. The clutch is decent and I didn't find it at all on the heavy side.
So I think the Edmunds guys maybe need to eat less and work out more
The only vibrations i have noticed is when the roads start to get rough like those in our crappy city, there is felt vibrations through the gas pedal, shifter and at times, the steering wheel.
Originally Posted by logik05se
just out of curiosty....though the clutch doesnt bother me one bit, i do notice that if you dont drive "correctly" that it will have jerky 1-2 shifts (which i know how to get around anyway)...but what exactly causes that?
There is a latency that one needs to get used to.
Plus the gear ratio difference comes into the picture as well.
Originally Posted by max2k1
Personally, I think the biggest deal is the time it takes for the rpms to drop off once you let off the gas.
its not really that...i mean if your not carefull with how you drive it and u just plant the clutch down in the first gear you will watch the passengers head jerk lol. This doesnt happen anymore for me but its only because I control it.
Took an '07 out for a test drive with the 6MT.... Wanted it so-o-o o badly to get back to a clutch/standard but after a weekend of tossing and turning decided on the 5AT S.
And now hearing here and elsewhere that they are redesigning the clutch for the G37, I do believe there are some issues with it.
Mind sharing what your new technique is ?? I don't really slam the clutch - but I have to focus on the 1-2 shift for sure ....
I really happen to like the clutch on the 07 alot. The 06 coupe clutch to me was absolutly terrible even though i learned to cope with it and drive it good. The 07 to me is much easier to handle and has much better response and feel.
Tried a different 6MT and it was the same.. went with the 5AT.
When I drove the 2006 G35 6MT, it didnt feel as bad as the 07 G35...
Originally Posted by Rounder
The Edmunds write up is correct, this clutch could/should be way better. Oh well no car is perfect. trafic sucks, everything else is awesome
I dont see myself owning this car for more than a couple years, chicago traffic sucks, all the other sticks i have driven are WAY smoother
The clutch is better in my wife's '02 Honda CR-V!
#30
Originally Posted by CarNutz
Did the same.. First test drive with the 6MT and I asked to try another because I thought it was defective, salesman agreed.
it just needed a little time to break in...mine works 10 times better then when i first picked the car up. As far as it being better then an 06 6mt you are out of your mind. I owned the 06 and now own the 07 and its really night and day. Even a friend of mine drove it who picked up his 06 coupe the same time as me and he said how much better the clutch is. After about 600 miles the clutch broke in nicely and works much better.
And as for your wifes cr-v. Honda has one of THE best clutch/sticks out there.
If you chose the 5at over the 6mt just because of a 10 min test drive, then you probably were leaning more towards the auto in the first place and just didnt want to admit it.
Because i was stuck between the 2 before i picked it up as well, and 1 test drive and i was sold on the 6mt.
