"harsh" engine sound
Old May 2, 2007 | 10:12 PM
  #31
hokiesean24's Avatar
I tested it out while paying attention this evening and once the car was nice and warm, it didnt do it as suspected...
very interesting indeed-
Old May 3, 2007 | 12:18 AM
  #32
nghiars's Avatar
Originally Posted by joeldoss
You should read the Car & Driver comparo with the BMW 328i...
http://www.caranddriver.com/comparis...-bmw-328i.html
I believe what you're hearing is something that the Car & Driver guys dislike about this car, "a lack of harmony in the engine compartment."
and its only car and driver who always says the bmw is more refined than the G.. those old fogies are more biased than Jim Crowe... its just the sound of the motor.. ive owned many nissans and that how they roar.. i dont see it as a bad thing i guess becuase im used to it and the fact the this V6 and different versions of it has one top ten motor awards for 13 years running.
Old May 3, 2007 | 08:36 AM
  #33
CarNutz's Avatar
The in-line 6's used in the BMW's are more refined. It's inherent in the design. A large bore V6 is going to sound and feel harsh. The in-line six built by BMW is about as good as it gets when it comes to smooth and refined.
Old May 3, 2007 | 09:27 AM
  #34
Altersys's Avatar
honda V6's do sound smoother.
Old May 3, 2007 | 11:10 AM
  #35
CarNutz's Avatar
I agree... Honda makes some of the finest engines on the planet... They sweat the details.
In-line 6's are more expensive and complex to build.. but because of the firing order and the long crank shaft.. they are inherently smooth running, also more expensive to build and they take up more space..
The V6 is more compact and cheaper to build... not near as smooth in operation especially the larger displacement designs.
Old May 3, 2007 | 11:31 AM
  #36
Altersys's Avatar
curious... why do you say I-6's cost more to build? I'm not arguing... wondering because it sounds like you may have insight. is it just materials quantity due to the less space-efficient design, or something more esoteric?
Old May 3, 2007 | 11:47 AM
  #37
CarNutz's Avatar
The parts are more expensive to build and work with. For example, the crankshaft and cam shafts are twice as long. It takes more to machine these parts and they are more difficult to handle and install. I helped my son replace the cams on his M3. It was far more difficult to do than any V8 I ever worked on. The Crank is huge and requires more main bearings than a V design. This and the firing order are key to the smoothness found in these engines. BMW really engineered their inline 6's for refinement.
TWASkyliner
Feb 8, 2020 08:00 PM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
03sedang35
Aug 29, 2015 07:56 PM
derres
Aug 28, 2015 03:27 PM
ghost_g35
Aug 7, 2015 10:31 AM
