turning off horn when arming the alarm
Old May 8, 2007 | 04:14 PM
hokiesean24's Avatar
Originally Posted by max2k1
Unfortunately, this also disables the "chirp" from the iKey door button (which I like)
its not seriously called an iKey is it?!?! What is it an Apple product?!?! I seriously do NOT want to have to sell my car...
Old May 8, 2007 | 06:07 PM
max2k1's Avatar
I've gotten tired of typing intelligent Key -- so I started using iKey
Its a Siemen's product btw (in case you don't like that company either )
Old May 8, 2007 | 06:46 PM
johannaccord1's Avatar
Originally Posted by SPEEED
I like the chirp but hate the horn. I can't understand for the life of me why Infiniti/Nissan would put a cool chirp on the door handle but leave the horrendous "it sounds like a domestic car" horn sound for the fob...
+1 thats why I had my horn changed to hella..sounds way better than stock horn
Old May 8, 2007 | 07:42 PM
max2k1's Avatar
Interesting ... never thought of a horn swap
So how easy was the swap (de-install, install etc ?)
What do these horns cost approx ??
Any sound clips of your horn "honking" ??
Old Dec 11, 2011 | 07:47 PM
Roadtrip's Avatar
I am reviving this thread 4.5 years later! I know I have to push both lock and unlock on remote i-key fob to change modes from chirping/honking to not chirping/honking. But here's the rub, I have used chirp mode by pressing request switches on door handles for years now. Suddenly, no chirping. I thought somehow my mode got changed. I pressed both lock and unlock on remote simultaneously for way more than 2 seconds as required in owners manual and no change. I tried with other remote and same thing: no change state. How do I change from silent mode back to honk/chirp mode? Somethings screwed up with my car I think. All Nissans and infinitis change chirp/honk mode by pressing both lock unlock key fob buttons simultaneously, but mine seems to be stuck in no chirp/honk mode for some reason. Thanks.
Old Aug 9, 2012 | 06:15 PM
Roadtrip's Avatar
I'll revive this thread again! I fixed this problem a while ago. Not sure what happened. Using computer at dealer, once connected to vehicle, there are even more options that you can pick from for setting chirps and honks when locking and unlocking. I found honk annoying , too noisy. Lights flashing is good enough indication for me.
When pressing lock and unlock buttons on remote you are limited to two choices only: either honk when lock using key fob and chirp when use request switch OR No honk, no chirp. With dealer computer you can actually pick and choose what you want more specifically. Now when I lock car with remote it's set up to flash lights but not honk when locking with key fob but still chirp if I use request switch. There is probably a whole host of things you can configure with their PC...
I had them disable low battery warning that appears on IP center display for key fob too. That warning has been on for at least 3 years now and I am still using the OEM battery from March 2008 LOL!!! I figure the day it stops working I'll know and will put a new battery in (that I have been carrying around for 3 years just in case!). Really, why throw a battery out that still works? I think low battery warning is set to go off way too early.
Old Aug 10, 2012 | 01:00 PM
maizer89's Avatar
wow roadtrip something to talk to the dealer about then, how much did they charge for the computer access, and wow i would replace that battery would suck for the battery acid to one day leak out and ruin your key
Old Aug 10, 2012 | 01:39 PM
Roadtrip's Avatar
Mechanic is a friend of mine so he hooked me up.
LOL! Don't worry about battery leaking. It has to stop working first before leakage starts!... I'm pretty sure about this anyway. When it stops working, I will swap it out.
jilljann1
Jul 21, 2020 08:12 AM
mattdg35
Sep 14, 2015 11:28 AM
NJ6MT
Sep 10, 2015 08:40 AM
pasjr1972
Sep 1, 2015 10:17 PM
