Can rims cause brakes to make noise?
Old May 26, 2007 | 08:56 PM
logik05se's Avatar
Yesterday I put new rims on my car (pics are coming soon) and i let my friend take it aroudn the block to see them while moving. As he went to park it, just as he was coming to a complete stop i herd them make a noise. Not a sqeak, ive heard this kind of noise before but i cant really explain it. I noticed today that it was happening quite a few times. If im driving at any speed and press the brake you will not hear it. If im slowing down with my foot constantly on the brake you still will not hear it. Its only when the car gets to about 5 mph and under that it makes the noise. If I lift my foot quickly then reapply it goes away as well. I'm assuming this is just brake dust, but i am a lil paranoid because i only started hearing it since i put the wheels on. Could this be anything related to the new wheels or am i just driving myself nuts?
Old May 26, 2007 | 09:10 PM
g_up's Avatar
i just noticed the same thing about mine last nite and i just put rims on my car about a week ago i was wondering wut the news was it sounds like it was coming from the back wheels
Old May 26, 2007 | 09:19 PM
Texasscout's Avatar
Retorque your lug nuts.
Old May 27, 2007 | 02:07 AM
logik05se's Avatar
seriosly? They were put on with an air gun, i usually like doing them by hand better though. So your saying i should make them tighter or a little less tight?
Old May 27, 2007 | 09:07 AM
Texasscout's Avatar
No, make sure they are set to 85 ft/lbs.
ALL aftermarket (and OEM) wheel makers recommend that you check the wheel torque at 200, or so, miles after installation.
BTW, don't ever let someone use an air impact gun to "finish" torque your lug nuts. They will NEVER get them right. You MUST use a good torque wrench to finish them.
Old May 27, 2007 | 09:12 AM
g_up's Avatar
thanks i think ill try that also
rezendvous420
May 31, 2020 01:26 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
Jussaku
Jul 29, 2015 11:45 AM
joedaddy1
Jul 28, 2015 02:58 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
