Tire rotation???
Old Jun 3, 2007 | 11:56 PM
edpark30's Avatar
Tire rotation???
When should you rotate the tires? How many miles? Also, when should you get new tires? Any suggestions on brand names? Also, do you switch the front to back opposite (diagonally)?
Old Jun 4, 2007 | 12:02 AM
Canadian144's Avatar
Try looking in the Owner's manual.. I think it should all be there. For performance tires I would say Michelin Pilot Sport PS2 or Bridgestone Potenza's.
Old Jun 4, 2007 | 01:20 AM
terrycs's Avatar
It depends on which version G35 you buy. The Sport version does not require tire rotation. The G35x and Journey verisons do.
Old Jun 4, 2007 | 01:34 AM
nate4598's Avatar
is your car lowered or not?
Old Jun 4, 2007 | 09:40 AM
gdbjr's Avatar
Is it that it isn't required, or that you just can't rotate them since the tires are different size front to back?
Old Jun 4, 2007 | 10:18 AM
HungNg85's Avatar
I believe I read in the manual and it says it's not required for S (is it because the front is 17in and back is 18in?). Mine is 35x and it says I need to swap front to back and back to front (not side by side) every 7500miles.
Old Jun 4, 2007 | 10:24 AM
terrycs's Avatar
The fronts are 225, the rears are 245, therefore rotaion is not required (not possible). The wheels are also keyed to prevent this.
Old Jun 4, 2007 | 11:18 AM
max2k1's Avatar
Both are 18s in the Sport -- however the rear tires are wider than the front tires -- that's why you can't rotate front to back.
Old Jun 4, 2007 | 12:55 PM
theacolyte's Avatar
Spoon!
As others have said, front tires are 225, back tires are 245.
On top of that, at least with the sport, the tires are asymetrical. So you couldn't even rotate laterally (if you wanted to).
Old Jun 4, 2007 | 01:12 PM
Tiger's Avatar
Yes you can. It's directional tires that you can't rotate from side to side.
You also asked about wear. There is an indicator built into every tire called a "wear bar/stripe." When this is flush with the surface of the tire, it's time to "re-tire."
Old Jun 4, 2007 | 01:22 PM
theacolyte's Avatar
Spoon!
Got it. I thought you couldn't rotate side to side.
Didn't know about the wear bar either, nice tip.
magnetism80
Feb 1, 2019 10:00 AM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
NJ6MT
Sep 10, 2015 08:40 AM
philthethrilloh
Sep 9, 2015 01:25 AM
