Do the windows open by themselves?
Old Aug 3, 2007 | 01:32 AM
cws's Avatar
cws
Originally Posted by hullio
Sorry to go off-topic, but the range is really short and so is there anyway to increase it?
Try holding the fob against your jawbone, with mouth open. It worked with my old Toyota, increasing the distance by about 50% - haven't tried it recently.
Old Aug 3, 2007 | 06:27 AM
bruddahmanmatt's Avatar
Originally Posted by ugaexploder
when i hold the unlock key it only opens the driver and passenger side.
one of you said it only rolls down passenger..that's weird. is there a way to change how many windows you can roll down. i've only seen mine roll down passenger and driver side
For the guy who said that only his passenger window drops, his driver's side window's auto up/down probably got deprogrammed. To reprogram the auto up/down, roll down the window and keep your finger on the button and hold it for 5 seconds after the window has been dropped all the way. Then roll it all the way back up and hold the button for 5 seconds after your window has been rolled up all the way. This will reset your auto up/down for the particular window you do this for and now both windows should drop when using your FOB since it utilizes the auto down feature to drop the windows from the remote.
Old Aug 3, 2007 | 12:55 PM
Trance_G35's Avatar
Originally Posted by wrxrocks
You have to use the actual key and the windows will roll up without turning on the car.
ah well thats a bummer it should work both ways oh well...
Old Aug 3, 2007 | 01:03 PM
g354jb's Avatar
If you hold your 'Unlock' button only the 4 windows roll down, not the sunroof.
You're right, only the windows open, not the sunroof.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
