Itb07-034 - '07 Sedan; Door Weatherstrip Loose
Old Aug 28, 2007 | 08:55 PM
treacherous's Avatar
20 Year Member
G35x
Bulletin Posted ITB07-034 - '07 Sedan; Door Weatherstrip Loose
DOOR WEATHERSTRIP LOOSE
IF YOU CONFIRM
The front or rear door weatherstrip has pulled out or loose a little or a lot
ACTIONS
Do not replace the door weatherstrip.
Re-insert the weatherstrip into the door channel using the Service Procedure in this bulletin.
http://x.infinitihelp.com/forum/loca...s.php?catid=77
I'd upload but PDF is too large.
Old Aug 28, 2007 | 09:12 PM
wesscyder's Avatar
IF YOU CONFIRM
ACTIONS
I had this problem on both the driver side door and the passenger side door. I just re-inserted it when I saw it. Hmm let me see what the service procedure says.
Old Aug 28, 2007 | 09:29 PM
wesscyder's Avatar
Here is service procedure.
Thanks. Damn that is some extra work.
Old Aug 30, 2007 | 01:29 PM
kanani's Avatar
Had mine at the dealer yesterday and had them look at this for the second time and there is no permanent fix for this. Just a bad design.
Old Aug 30, 2007 | 01:39 PM
Christian's Avatar
Here's a direct link to the PDF:
ITB07-037.pdf - Door Weatherstrip Loose
I also added it to the FAQ sticky.
Old Aug 30, 2007 | 01:50 PM
blindS!de's Avatar
Got the dealer fix this for me, so far so good hopefully it doesn't come loose again...
jsimonk
Dec 22, 2023 03:49 PM
si_driver
Aug 11, 2015 07:08 AM
will091195
Jul 27, 2015 09:19 PM
ClwMike
Jul 23, 2015 12:55 PM
