SQUEAKY BRAKE PEDAL, WINDOW, & other annoying issues
Old Aug 29, 2007 | 05:17 PM
PawnPIMP's Avatar
I have been having two annoying problems. Squeaky brake pedal and squeaky driver side window.
The brake pedal squeaks every time I press and release the brake pedal. Any solutions?
The driver side window squeaks when ever it goes up or down when it rains. I do have window tints. The other windows are fine, except the driver front window. Again, any solutions?
Metallic Vibration in the front dash only after I had the stillen air intake installed.
Other annoying problems, which have been fixed or still go on
-Rattling from the passenger pillar, nothing they can do "F*%k you I say"
-Led's on the shift control went out twice. They replaced the lights the first time, then replaced the unit the second time.
-Wanted to charge me 200 to install mudflaps. "F you again"
-Left adaptive head light stop working--replaced.
-when forwarding through a song, it doesn't forward or rewind with a good response, unlike the loaner car that had no navigation.
The good news is that I get free food when I go there. The Panini Rocks, and the breakfast is good.
Please help
Old Aug 29, 2007 | 06:00 PM
SPEEED's Avatar
Bad Toro
For the brake pedals you can try WD-40 on the hinges of the pedals (assuming the source of the squeak is within reach). For the window, I'd say take it to the dealer. Most likely you have some sort of fine debris that got stuck in there and its rubbing on when you roll down/up the window. The down side is that you have tints, for which the dealer may decline to fix the problem under warranty. Alternately, you can go back to your tint installer and have him take a look.
Good luck.
Popes
Jul 29, 2015 05:07 PM
Jussaku
Jul 29, 2015 11:45 AM
apintojr
Jul 23, 2015 10:52 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
